I recently purchased a Nine Inch housing from Currie. I had them weld on a set of spring perches to what they said was the factory setting for pinion angle.
After I installed the rear end I notice a small vibration in the driveline. I began to investigate and noticed that the rear pinion is pointing down approx. 4 degree's.
Can anyone tell me if that is the proper angle or if it matches a Nine inch in your own car.
Thanks for any input.
