  • SN95 4.6L Mustang Tech
nitrous and AFR questions
  • Thread starter Thread starter Bullitt0616
  • Start date Start date Sep 8, 2005
Bullitt0616
96
  • Sep 8, 2005
im used to dealing with RX-7s concerning nitrous in whcih wet systems are usually the better choice above 50hp shots.
now im a stanger, what's typically better for, lets say, a 100hp shot? what if i wanted something bigger?
that brings me to my next question: how do stangs usually run in terms of air/fuel ratio? rx-7's a naturally pig rich, are we more balanced, rich or lean?
forpit2000gt
2,490
Columbia, SC
Sep 8, 2005
  • Sep 8, 2005
If you are not lean N/A and you use a wet kit, say an NX, then there won't be any AF problems if you run the correct jets. If you run above a 125 shot you may need a fuel pump to deliver enough fuel. Some run up to 150 that I've seen with no problems, but you are getting close and may lean out . Get a dyno tune after the kit and see where the AF is . Do not go by some pretty AF guage and expect to be accurate.
Bullitt0616
96
  • Sep 8, 2005
so do mustangs run abit on the rich side or lean side?
i ask only out of curiousity, i dont go by AFR gauges unless theyre wideband connected or dyno tuning.
forpit2000gt
2,490
Columbia, SC
Sep 8, 2005
  • Sep 8, 2005
that would depend on tune or mods. If you has some aftermarket MAF housing, it may be a little lean. If you change to free flowing exaust you may have the opposite. They do not run pig rich or lean normally. Without a wideband you will not know.
The Towering Inferno (the 1970 Mach 1 Version)
  • CarMichael Angelo
  • Feb 14, 2016
2K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Feb 19, 2016
smokin joe
  • Locked
Just Some Suggestion's For Foxes
  • Detroiit
  • Jul 24, 2014
2K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jul 25, 2014
A New Easy Way To Really Dial In A Tune?
  • FastDriver
  • Sep 11, 2013
8K
Fox 5.0 Mustang Tech Sep 23, 2013
FastDriver
RANT!!! Deer Hunting Rant . . . yes, RANT! Lots of words . . .
  • D Durden
  • Nov 29, 2012
  • Survival Stall
Survival Stall May 27, 2014
Gearbanger 101
  • Locked
FS: HSW Nitrous System w/Extras
  • bgdowski
  • Oct 3, 2011
  • Engine and Power Adder
Engine and Power Adder Oct 4, 2011
bgdowski
