FS: HSW Nitrous System w/Extras
Harris Speed Works nitrous system. 8 bottles through everything, selling to fund a motor build. Comes with heater, so the bottle has never had a torch to it. Pictures can be sent or added as requested, just PM or post your email/phone and ill get them to you in a timely manner. Shipping is at buyers expense, or will meet within reason. If shipped, ill have to empty the bottle. Price is $675 obo. I would prefer not to separate, unless i have multiple people interested in diff. parts. Possibly interested in SBF parts.
-Single nozzle setup, wet kit.
-Fuel & Nitrous 'noid is HSW, along with lines and nozzle.
-10lb HSW bottle
-Array of pills
-Bottle Brackets
-Bottle is currently full
-Pressure controlled bottle heater
- Sender is NOS brand
- Heater is DynoTune brand
-On-bottle pressure gauge
-HSW Brand
-Purge 'noid
-HSW Brand
-Switch panel designed for 3rd gen F-body ashtray
-Arm switch, Heater switch, Purge button, and two Acc. Switches.
-Missing a tab for mounting, but can be made easily.
-Currently mounted in a Radioshack Project Box with relays mounted inside
-3 Relays for F&N 'noids, Heater, and purge 'noid
-WOT switch with 5.0L EFI mounting bracket
-Universal 'noid mounting bracket
-Harris Speed Works MicroEdge Nitrous controller
-Features of The MicroEdge:
RPM Window Switch: Only operates the nitrous system within a set “window” of RPM.
TPS Activation Switch: Only operates the nitrous system at (WOT) wide open throttle.
Dual Stage Control: Allows for the use of multiple nitrous kits to be run off of one (1) window switch. IE; multiple stages which can be used with different RPM & TPS values.
A/F Shut Down Switch: Nitrous system(s) will shut down if a lean condition is detected by either a wideband O2 sensor or narrowband O2 sensor. The MicroEdge will also shut down the system if an overly rich A/F is detected (wideband sensor only).
Lean Out Delay: The MicroEdge controller can be programmed to not shut down the nitrous system for a determined amount of time if a lean condition is detected. Great feature for those small lean spikes upon kit activation. This feature can be adjusted up to 10 seconds in .05 second intervals.
Multi-Gear Lock-Out: Can be configured for both stages and can lock-out multiple gears to optimize traction.
Time Delays: Activation of kits can be delayed for up to 10 seconds in .05 second intervals.
Pedal Delay: Delay(s) used to re-gain traction if the system is activated and the gas pedal is let off due to wheel spin and then re-applied. This allows for momentum to be built prior to re-activating the nitrous system(s). Both stages have their own pedal delay which is adjustable up to 10 seconds in .05 second intervals.
Nitrous Solenoid Delay: Delays the nitrous solenoid from being activated for an amount of time after the kit is activated. This helps to cure any lean spike issues that are pre-existing in the system.
Display: Built in LCD display can show RPM, A/F Ratio (mV for narrowband), TPS voltage, Battery Voltage, and Arming Switch Voltage.
File System: Up to three (3) files can be saved within the MicroEdge unit for quick and easy loading between runs.
Upgradeable: Easily upgradeable to the MicroEdge+ for progressive control features.
More info on the parts can be found on their website. Feel free to ask any questions, im motivated to sell.
