  • SN95 4.6L Mustang Tech
nitrous cam question
  • Thread starter Thread starter stangdrvr06
  • Start date Start date Aug 11, 2008
stangdrvr06
42
  • Aug 11, 2008
Hey guys I wanted to know if there is a nitrous cam out there for our cars. I wanna do nitrous 100 shot plus a cam. I was initially going to get the stage 2 comp cams but I heard a buddy mention nitrous cam. So I'm wondering where can I buy one if it exists. If not then what cam would be best for a nitrous set up. Thanks for the help.
Posted via Mobile Device
G
Greenbird
34
  • Aug 11, 2008
You don't need or want a "nitrous cam" for a 100 shot.
stangdrvr06
42
  • Aug 11, 2008
Oh really? So a regular cam would suffice.
CobraRed_96_GT
1,421
UCSD/La Jolla
Aug 11, 2008
  • Aug 11, 2008
Yup, a nitrous cams are more for people using nitrous on their drag car that sees spray every run each week.
COramprat
...I can take it. I think.
20+ Year Stangneter
Mar 2, 2003
8,474
1,463
223
Sea of Tranquility
Aug 11, 2008
  • Aug 11, 2008
If you wanted to upgrade just look at cams as if you were a normally aspirated motor. The nitrous would just add to the kick.
stangdrvr06
42
  • Aug 11, 2008
So if I was to go with a stage 2 comp cams from americanmuscle.com. What else would I need with cams.
BurningRubber
1,865
24
58
Aug 11, 2008
  • Aug 11, 2008
Well, its not 1 cam. Its two cams, and yes the stockers will be more than fine to run nitrous.
It would be WAY WAY WAY too expensive to get a nitrous-ground cam for a 100 shot only. If you built the motor to handle a large shot of nitrous, then yes.
For now run a 100 shot, if you feel that you need more, bump it up to a 125 shot.
With a good tune and a motor in good health you can run a 150 shot if you are still needing more.
stangdrvr06
42
  • Aug 11, 2008
yeah i just wanted to do a nitrous + cam combo. Just wanted to know what i needed. thanks for the help. with cams would else would i needa get. i don't wanna waste my money on things i wouldnt need. just what i would need with cams. springs etc?
BurningRubber
1,865
24
58
Aug 12, 2008
  • Aug 12, 2008
Depending on the specs of the cam, you may or may not need new springs.
I havn't really seen any nitrous specific cams for sale for the 2v crowd, probaly something that if you wanted to do right to get a custom grind. Expensive, but it would be done right.
If you didn't want to do that, I'm sure there are some cam's that arent nitrous specific, but the specs may be nitrous freindly more-so than others.
If that is what you really want to do, then you should go for it.
Its just my opinion that it is not worth the money and hassle for the cams on top of nitrous, when you are still limited to around 400rwhp on the stock short block if you want any kind of life in the motor.
You can easily get to that mark with a hit of nitrous alone.
CobraRed_96_GT
1,421
UCSD/La Jolla
Aug 12, 2008
#10
  • Aug 12, 2008
  • #10
Yes you need springs with stage 2's, but like Burining said there's not really a reason to go at cams when you want nitrous as you're limited by the rods with the power you can reach. And a stage II cam is pretty drastic regardless
J
Fox Cam swap gone wrong??
  • Jimmer009
  • Apr 21, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Apr 27, 2025
Jimmer009
J
  • 68_Disgustang
  • Feb 22, 2026
1965 - 1973 Classic Mustangs -General/Talk- Oct 19, 2026
mattcrp1
M
Y
Cams in Ca?
  • yelol2v
  • May 12, 2024
1996 - 2004 SN95 Mustang -General/Talk- Sep 1, 2024
2vVert
  • B0udreaux
  • Jul 14, 2026
AeroCoupe
G
Drivetrain trickflow Stage 3 camshaft 347 stroker. also too much gear????
  • Gross Virgin
  • May 2, 2024
Fox 5.0 Mustang Tech May 2, 2024
Gross Virgin
G
