the98stang
holy sh1t....your lucky you didn't puddle the intake with a 200 shot! How long did you spray it with that shot?
see how i am looking at it is i can setup the controller to slowly add more and more nitrous into the motor as teh rpms increase instead of all at once. so i can maybe start at like 60% and then increase throughout the rpm range and be at 100% by like 4500 or so.
so i was just wondering if u guys thought this logic would help out the longevity of the motor. or at least allow me to run a bigger shot of nitrous longer before she lets go.
yea ill spray the 150 but i am going to cam the car and put headers on it. My plan is to run 12s on motor and then run in the 11s on spray.
I am getting a wideband here soon and then changing over my tuner to the sniper stuff so i can do a little bit more. Ill also upgrade the fuel pump and then eventually i will put new rods and pistons in it.
K, just keep in mind that with header installs they almost always leak. Exhaust leaks will **** with your a/f reading on the wideband, so make sure you get em sealed up good.![]()
