Nitrous Install Problems
  • Thread starter Thread starter YawnY
  • Start date Start date May 14, 2011
Y
YawnY
42
  • May 14, 2011
I have an issue when installing my NOS kit, its the direct port that has the spacer going in-between the upper and lower intakes.
I got every in and set-up but when trying to install the solenoids onto the fuel/nitrous inlets on the nitrous plate the metal lines wouldn't fit properly and I could not fit the solenoids along the fuel rail, the metal lines would hit the upper intake and the solenoids would not clear the injectors or rail.
Anyone ever had this issue or know a way around this?
This is the install manual for it. I have the GT-40 intake on my car.
http://www.holley.com/data/Products/Technical/A5076-SNOS.pdf
Any help would be really REALLY Appreciated.
Rick 91GT
Mustang Master
95
99
PA
May 14, 2011
  • May 14, 2011
Ive had to rebend lines out of some kits in the past, do you have a tubing bender, is the spacer on in the correct direction?
Y
YawnY
42
  • May 14, 2011
I can get a brake line bending tool but not sure if that will work, and I'm certain its on the proper way, Nitrous (blue) is on the drivers side.
Y
YawnY
42
  • May 14, 2011
See the issue is how much room between the solenoids and the fuel rail, doesn't seem like it matches up at all, and the lines are just not even close.
Rick 91GT
Mustang Master
95
99
PA
May 15, 2011
  • May 15, 2011
If they are way off call Holley, othwrwise youll have to get some line and bend them yourself.
Engine Looking for suggestions and or ideas
  • PonyGTrider
  • Aug 25, 2026
PonyGTrider
  • dan50
  • Jul 18, 2026
dan50
Fox Fuel Pump Issues After Replacement/Upgrade
  • Ryu
  • Jun 23, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 13, 2026
Ryu
C
03 Cobra Low Fuel Pressure
  • CTsnake_03
  • Mar 17, 2026
1996 - 2004 SN95 Mustang -General/Talk- Mar 24, 2026
CTsnake_03
C
M
01 mustang 3.8 fuel pressure issue
  • Mhaley2006
  • May 29, 2026
1996 - 2004 SN95 Mustang -General/Talk- Aug 9, 2026
JohnKay
J
