  • 1994 - 1995 Specific Tech
Nitrous Question
  • Thread starter Thread starter Guero
  • Start date Start date Feb 15, 2006
Guero
2,148
Feb 15, 2006
  • Feb 15, 2006
I was talking to my freind and told him , i finally got Notrous, then he told me, that everytime i spray i will take 4000 miles away from my engine, i didn't say nothing but i think thats is it ?
94gts
873
Carmel, New York
Feb 15, 2006
  • Feb 15, 2006
so in my case that means i took 200,000 miles off of my motor:SNSign:
9 bottles x 50 times sprayed roughly x 4000 miles = 200,000 k
that means my block would last to atleast 311,000 miles (i have 111k now)
Nitrous isnt the BEST thing for your motor, but as long as nothing goes wrong you are fine. Everything will either work really well or blow up really bad
SWYZ721
208
Ann Arbor, MI
Feb 15, 2006
  • Feb 15, 2006
Absolute garbage. With that logic I could spray a 500 shot on my brand new motor and I would be good until I got up around 150K which is when 5.0s typically need refreshning
Nitrous increases cylinder pressure, just like any other power adder. It is all in the tune, however, a nitrous controller would make the power more "engine" like, so the trans and pistons don't get a shockwave of energy, but that still might be insignificant.
FORCED2DV8
458
Grand Rapids MI
Feb 16, 2006
  • Feb 16, 2006
Tell your friend its better to be silent. Because makes him look stupid.
Swarzkopf
973
Pittsburgh
Feb 16, 2006
  • Feb 16, 2006
Yup. Total BS.
Nitrous injected properly is no more detrimental to an engine's health than any other means of making power.
My bone stock 95 5.0L engine has 90,000 miles on it and has had multiple passes and street runs on a dry 125 shot during the past two years. It's fine, and a compression test just showed that all of the cylinders are between 135-144 (seven of them between 139-144), typical for a 5.0 with this mileage- indicating no excessive wear due to the nitrous.
9
98Fauxbra
74
Hotlanta, GA.
Feb 16, 2006
  • Feb 16, 2006
Gotta chime in too. I didn't start spraying mine till 125,000 and when I tore it down at 160,000 it still looked brand new inside. I didn't even do the bottom end. It still had good compression and oil pressure so I started bolting stuff on. At 170,000 now and it is still strong! I used the zex dry kit and loved it. I only sold it to start the bank for a 331 stroker to bolt all of my new parts on. Highly recommended!
J
can you use the heads off a H O 302 to put on a regular 302 engine
  • Jan H
  • Feb 25, 2026
  • Other Auto Tech
Other Auto Tech May 17, 2026
nickyb
Need help and Advise - 89 Problem Child
  • Sheela
  • Oct 28, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Oct 28, 2025
evintho
Need some camshaft guru advice on power loss from supercharger to nitrous
  • TTSaleen
  • Dec 1, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Dec 29, 2025
revhead347
J
Switched to e85 on the 3v and now it won't run right.
  • jcowdough
  • Aug 24, 2025
2005 - 2014 S-197 Mustang -General/Talk- Aug 24, 2025
Engine Another no start after washing engine bay
  • bruno
  • Apr 26, 2026
Fox 5.0 Mustang Tech May 7, 2026
AeroCoupe
