  • 1994 - 1995 Specific Tech
Nitrous Setup Question
  • Thread starter Thread starter Guero
  • Start date Start date Feb 22, 2006
1 of 2 Next Last
Guero
2,148
Feb 22, 2006
  • Feb 22, 2006
I finally got my ZEX Dry Kit today, and was wondering how hard it was cuz the instructions suck, any one have a site or something on some detailed instructions?
69clark
731
Ravena, NY
Feb 22, 2006
  • Feb 22, 2006
It's should be pretty easy. I have the same kit and although the instructions are pretty basic it should be all you need. Just be sure you use the right TPS wire to connect into. I didn't test the wire when I hooked mine up, I just used a Haynes manual and it seems that they had a misprint on the 3 wires to the TPS. I used the wire the manual said and it was actually reversed, so after trying to figure out my problem I tested the wire myself and found the problem. The wire you need is the signal wire. Other than that it was really easy to install. Good luck, let us know how it goes.
Guero
2,148
Feb 22, 2006
  • Feb 22, 2006
Guero
2,148
Feb 22, 2006
  • Feb 22, 2006
and how long should it take?
94gts
873
Carmel, New York
Feb 22, 2006
  • Feb 22, 2006
god that zex kit is too dam complicated
my old kit was a converted carb kit. 0 safetly measures but it worked!!! 9 whole bottles
Guero
2,148
Feb 22, 2006
  • Feb 22, 2006
is it the middle wire i tap into the TPS?
69clark
731
Ravena, NY
Feb 22, 2006
  • Feb 22, 2006
Should only take you a couple of hours unless you take more time to make sure everything is right, neat, and tighty. The signal wire you need to connect into is the signal wire to the TPS. The zex system is activated at full throttle, so this is why you need to tap into the TPS signal wire.
Unless I am mistaken you have one of the zex smart systems right (not sure if that is the proper name but it comes with the purple box that controls everything, right?)
69clark
731
Ravena, NY
Feb 22, 2006
  • Feb 22, 2006
Guero- I not 100% sure, my memory isn't working well right now, but it is the wire that if you put a volt meter on it, it should show about .99v at closed throttle and about 5v at WOT. Hope this helps.
69clark
731
Ravena, NY
Feb 22, 2006
  • Feb 22, 2006
Guero- I searched some other posts and from what I can find it is the middle wire on the tps connector. Hope this helps.
Guero
2,148
Feb 23, 2006
#10
  • Feb 23, 2006
  • #10
ok thanks. and yes i do have the purple box. Now what i dont understand is were do i connect the intake hose from the box and the regulator hose? i understood everything else now except that
69clark
731
Ravena, NY
Feb 23, 2006
#11
  • Feb 23, 2006
  • #11
I believe that those hose hooks up to the fuel pressure regulator, it is used to provide the right amount of fuel when the nitrous is being used.
Guero
2,148
Feb 23, 2006
#12
  • Feb 23, 2006
  • #12
were is it located? and how bout the intake one?
69clark
731
Ravena, NY
Feb 23, 2006
#13
  • Feb 23, 2006
  • #13
The fuel pressure regulator should be on your fuel rail. It is in the back near the firewall on the passenger side. I am having a brain fart on the intake hose but I think it just hooks up to a vacuum port on the intake. I will have to check just to make sure, like I said I am having a brain fart.
Guero
2,148
Feb 23, 2006
#14
  • Feb 23, 2006
  • #14
so i need like a t-hose? to connect all those up?
69clark
731
Ravena, NY
Feb 23, 2006
#15
  • Feb 23, 2006
  • #15
Yeah probably unless you have an open or extra port already.
I'm surprised no one else has chimed in yet. LOL. I feel like I'm using instant messanger. lol
Guero
2,148
Feb 23, 2006
#16
  • Feb 23, 2006
  • #16
lol. thanks. im just gonna put everything exept for the regulater and intake them take it to my friend who is a mechanic.
95Vert
1,785
North Mexico (deep south Texas)
Feb 23, 2006
#17
  • Feb 23, 2006
  • #17
Very helpful info. I will be needing this.
D
dallas863
18
Clinton, Mississippi
Feb 23, 2006
#18
  • Feb 23, 2006
  • #18
I have the ZEX Dry kit on 95. The directions should show which port goes to the vaccum and which one goes to the regulator. You need a cold air kit also so that the injector can be bolted to.
Overall very very easy
Guero
2,148
Feb 23, 2006
#19
  • Feb 23, 2006
  • #19
i got one but thanks for trying to help, and thanks clark you've been very helpful
chefster
426
michigan
Feb 23, 2006
#20
  • Feb 23, 2006
  • #20
oK,I HAVE THE ZEX ON MY 94 COBRA...I DRILLED RIGHT INTO MY INTAKE JUST ALITTLE PAST THE THROTTLE BODY ..RAN HOSES UNDER CAR AND UP INTO TRUNK ...MY BOTTLE IS MOUNTED RIGHT BEHIND THE DRIVER SIDE FOLD DOWN SEAT WITH THE BOTTLETOP FACING THE CENTER OF CAR AND POINTING SLIGHTLY FORWARD WITH THE KNOB RIGHT THERE ALMOST TOUCHING THE FOLDDOWN SEAT BACKING...i CAN REACH BACK PULL DOWN SEATAND OPEN BOTTLE WITH ONE HAND SITTING AT A LIGHT..AND TAKE ON AN ADVERSARY..I AM VERY HAPPY WITH THE SET UP AND IT REALLY KICKS ASS...TOOK OUT A NEW GTO WITH IT....DON'T USE IT IN FIRST GEAR!
1 of 2 Next Last
Brake pad and rotor upgrade
  • Sparky714
  • Aug 7, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Aug 17, 2026
Sparky714
J
Power Wire Upgrade Question
  • jhaling
  • Dec 21, 2025
  • SN95 4.6L Mustang Tech
SN95 4.6L Mustang Tech Mar 23, 2026
R
Engine Evap and charcoal cannister leak
  • ryan1994stang
  • Mar 14, 2026
Fox 5.0 Mustang Tech Mar 18, 2026
Mcmahst
A
Blow through intercooled questions
  • AngryH58
  • Aug 31, 2026
1996 - 2004 SN95 Mustang -General/Talk- Sep 1, 2026
AngryH58
A
3.08 gears with a manual trans
  • limp
  • Aug 27, 2026
  • 2 3
2K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 14, 2026
Qtrhrse23
