  • SN95 4.6L Mustang Tech
Nitrous tapping
  • Thread starter Thread starter BurningRubber
  • Start date Start date Aug 29, 2007
BurningRubber
1,865
24
58
Aug 29, 2007
  • Aug 29, 2007
Ok, I have my eye set on some kits, and im leaning more towards a plate system for 1 reason.
I have a K&N FIPK on my GT, which is a plastic intake instead of metal like most others. Thats good, cause it doesnt hold heat like metal.
Im afraid that it would make it more difficult to drill/tap for a nitrous jet though. Is it just as easy as a metal intake tube or will it prove to be more difficult?
If not, I feel very close to being set on Cold Fusion, Zex, or possibly a re-worked NX Mainline kit.
If plate will be easier im going to most likely ****** (it wont let me say sn at ch...?) up a NX Mainline plate system.
the98stang
2,408
Clovis, CA
Aug 29, 2007
  • Aug 29, 2007
The FIPK would probably be easier to tap, because it's not metal. I do recommend the plate kit over the regualr jet kit though. The plate kit allows the nitrous/fuel to disperse more even into the cylinders because it does not have to travel as far. NX has great service too.
BurningRubber
1,865
24
58
Aug 29, 2007
  • Aug 29, 2007
Yeah the kit I am looking it is a NX Mainline kit with the plate added in, and the rest of the wiring/switches to make it complete. I like the fact that its NX quality but it doesnt offer a 75hp jet like many other kits do.
I want to stick to a fairly budget kit, thats $400. There are a couple of others ive seen under $400 that are nice looking kits, but not plate. ZEX also has some kits right over $500 that are nice. So many choices, its a real PITA... hahaha.
the98stang
2,408
Clovis, CA
Aug 30, 2007
  • Aug 30, 2007
Every kit I have seen offers a 75 shot, so I have no idea what kit you are looking at . Why not go for 100?
SamMan
121
Denton, TX
Aug 30, 2007
  • Aug 30, 2007
No worries on tapping the non metal intake tubes. I have a stock one and its been tapped for a while now with no issues. That all being the case though if I had it to do over again I would go with the NX plate system for the aforementioned reasons. Oh and 75shots are for wussies. You wouldnt leave that nozzle on for a week before it would be changed out for a larger one.
R
ROUSH1
34
  • Aug 30, 2007
i bought a basic edelbrock kit, and then bought an intake spacer and plumbed the e1 nozzle into that. running a 125 shot right now w/ no problems. here is the link where i got it.
http://dynamicracingproducts.com/AutoPartsStore/product_info.php?cPath=1_10&products_id=322
upr also makes one, but they were a little more expesive for the same exact thing.
BurningRubber
1,865
24
58
Aug 30, 2007
  • Aug 30, 2007
Thanks guys.
98stang- The kit im looking at is a re-packed "complete" NX mainline kit with a plate added on. It has 50-100-150 jets with the kit.
the98stang
2,408
Clovis, CA
Aug 30, 2007
  • Aug 30, 2007
BurningRubber said:
Thanks guys.
You'll be fine with a 100 shot as long as you have a window switch.
ACT sensor in plastic charge pipe
  • 92Rustang
  • Jul 23, 2024
2K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jul 31, 2024
92Rustang
  • D Durden
  • Oct 20, 2025
  • 2 3
3K
J
  • JRC99
  • Apr 19, 2025
JRC99
J
98 GT PI Swapped Engine Fires, Dies Immediately NOT PATS
  • MMccPerformance
  • Dec 2, 2023
2K
SN95 4.6L Mustang Tech Dec 20, 2023
Yel2002GTAuto
Y
Progress Thread H/C Swap Problems/Ideas
  • sav22rem22
  • Mar 31, 2024
2K
Fox 5.0 Mustang Tech Sep 10, 2024
AeroCoupe
