1. would 30 waist alot more gas? and how much are thise inj?Black95GTS said:1 - Yes, I believe that 24s are too small. I'm putting together a combo similar to yours and I personally feel that 24s are too small N/A, nevermind with N2O. Definately step it up to 30s. The injector pulse width will be a little harder to dial in (as Grady has taught me) but I'd rather tune more then ping more.
2 - Just one step colder. Stockers are autolite 25s, so switch to autolite 24s, etc.
3 - Yes, you need a new fuel pump even without the spray. Get a 255lph in tank pump and don't worry about it every again.
4 - While you are at it, just step it up to a 100 shot. You might as well.
5 - As far as timing is concerned, you're going to find that your car will run better with a little timing advance over stock anyway. Aluminum cylinder heads tend to like a bit more advance then irons do.
- Adam
3. how much is that fuel pump?
4. 100 shot seems to much for me, i think im gonna mess up my engine.
5. if you run nitrous doens't timing need to be set at stock to be safe?
Kiddin'.
