Before I get cute and do a google image search, what the heck is the #2 crossmember? Is that the one in between the shocktowers (under the oilpan) that bolts onto the frame rails, or is it the trans crossmember?
If it's the front one under the oil pan, you DON'T WANT TO cut the bolts. They are a funny taper bolt and you can't really buy them easily. Spray with BP blaster, hit them once or twice right in the middle as hard as you can with a ball peen hammer, and then use a 1/2 drive impact gun to remove them. They are on tight. Good luck.
