Hi iam new to this site this is my first post but, a very important one iam having a porblem getting the rear brakes to work on my 83' it seems as if no pressure is going to the rear ok here what i have did so far..
I replaced the master cylinder still did not fix it.
then i got a proportion valve from the junkyard damn fords it did not fit the lines on my car which was a v6 did not fit the valve ok soo we cleaned out the proportion valve that was on mine. When we bolted everything back up and cheaked to see if anything was coming out of the valve it was now, when we went to do a brake test to see if the rears worked once again still nothing. The next day we cheaked the lines i did not find any bends ect on the line leading from the front to the back of the car i even pressed the brake when i had the line disconected from the rear to see if it spit out fluid and, it DID and why would the line all of a sudden stop up? keep in mind i did not have this brake problem into we when from 7.5- V8 8.8. I asked around and sombody asked me did i change the wheel cylinders over to v8? I never thought you had to when making that swap all of them the same right?
anyhow i still do not know what to do iam pulling my hair and losing sleep and heath over this dose anybody on here knows what my problem could be ur help and advice i would really appreciate it. great site by the way
thinks mike
thinks mike
