no brakes?
tims 86
187
pittsburgh,pa
ok i am completely stumped! cant stand working on brakes anymore. so here is what i did. new mm front stainless hoses and the rear one on top of axle. upgraded front brakes to 94-95 calipers and rotors. bled about 3 quarts of brake fluid to clean system and get all the air out... no pedal at all??? so i figured new master cylinder,,,, no not it??? still no pedal at all... what am i missing? everything is tight to spec and no leaks anywere... possible bad calipers?? im so confused please help
everything was good till i did the changes, e- brake works, not sure how to test the booster but it worked before. pedal just goes to the floor with no resistance when car is running. that tells me the booster is ok. could it still need bled more? i did it soo much the fluid is so clean now and not getting any air.
You didn't change or move the calipers? A very common problem is to put them on the wrong side of the car, and they won't bleed if you do that. The bleeder must be up top.
Not really backwards, but upside down. They'll mount perfectly and they look normal, problem is, when mounted this way, an air pocket is trapped at the top of the caliper and cannot be bled out because it's above the level of the bleeder.
Reactions: 88LX5.Oh
