No codes at all (no code 12)
  • Thread starter Thread starter enyawix
  • Start date Start date Apr 11, 2006
enyawix
507
Apr 11, 2006
  • Apr 11, 2006
Constant beep when reader device plugged in. No beeps once key in accessory poison. Pump primes when reader is on test.
jrichker
StangNet's favorite TOOL
Mar 10, 2000
27,512
2,813
234
Dublin GA
Apr 12, 2006
  • Apr 12, 2006
There isn't enough information about your car to give the best answer. The wiring and computers changed several times between 86 & 93.
That's why it is a good idea to use the sig under the user control panel (User CP) option. It allows you to post your car year & mods, which help greatly when troubleshooting things. No, it is not there for us to snoop and see any "Secrets" you have hidden away under the hood. Be a good stangnetter and update you sig for future reference & don't keep us guessing.
enyawix
507
Apr 12, 2006
  • Apr 12, 2006
Now I have a signature
90 body 93 engine
jrichker
Mar 10, 2000
27,512
2,813
234
Dublin GA
Apr 12, 2006
  • Apr 12, 2006
What kind of reader are you using?
Try the paper clip or jumper wire as follows...
Dump the codes and see what the computer says is wrong…
Here's the link to dump the computer codes with only a jumper wire or paper clip and the check engine light, or test light or voltmeter. I’ve used it for years, and it works great.
See http://www.troublecodes.net/Ford/
OR
See http://www.mustangworks.com/articles/electronics/eec-iv_codes.html
IF your car is an 86-88 stang, you'll have to use the test lamp or voltmeter method. There is no functional check engine light on the 86-88's except possibly the Cali Mass Air cars.
For those who are intimidated by all the wires & connections, see http://www.actron.com/product_detail.php?pid=16153 for what a typical hand scanner looks like. Normal retail price is about $30 or so at AutoZone or Walmart.
Or for a nicer scanner see http://www.midwayautosupply.com/detailedproductdescription.asp?3829 – It has a 3 digit LCD display so that you don’t have to count flashes or beeps.. Cost is $35.
enyawix
507
Apr 13, 2006
  • Apr 13, 2006
Actton CP9015 I work at AutoZone so it was cheap. I need engine info because the car will not idle cold. I must give it gas until it warms up.
jrichker
Mar 10, 2000
27,512
2,813
234
Dublin GA
Apr 13, 2006
  • Apr 13, 2006
See the sticky "Help me create the Surging Idle Checklist" at the top
of the forum for help with your idle problems. The first post has all
the updated answers.
Note that all resistance tests must be done with power off. Measuring resistance with a circuit
powered on will give false readings and possibly damage the meter.
Most no code problems are due to wiring problems on the computer pin 46 signal ground wiring.
Pin 46 on the computer is a black/white wire that connects to power ground inside the computer.
Use an Ohmmeter and measure the resistance between the black/white wire on the computer
self test connector and the negative post on the battery. You should see less than 1.5 ohms.
More that that means wiring problems in the form of broken wiring or bad connections.
The other wire to check is the white/red wire (marked STI in the diagram). It is a single wire
with a gray plastic cover over the connector. Measure the resistance between it and pin 48
on the computer. You should see less than 1.5 ohms.
See the following website for some help from Tmoss (diagram designer) & Stang&2Birds
(website host) for help on 88-95 wiring http://www.veryuseful.com/mustang/tech/engine
http://www.veryuseful.com/mustang/tech/engine/images/88-91eecPinout.gif
Using the above diagram, you will find pin 30. Normally problems with pin 30 cause a code 67
and you can't get the computer to go into test mode with the engine running. Grounding pin 30
to pin 46 can be used to trick the computer to go from Key On, Engine Off test mode to
Key On, Engine Running test mode. But first you need to jumper the self test connector
properly to go into test mode.
  • Mindseye007
  • Aug 16, 2026
Mindseye007
92 5.0 almost starts
  • Steverino
  • Sep 23, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 25, 2026
General karthief
Engine Rough idle and aggressive sputtering when accelerating
  • 88vertible
  • Aug 13, 2025
Fox 5.0 Mustang Tech Dec 13, 2025
Jarhead67
J
  • brandyn200
  • Jun 20, 2026
AeroCoupe
Running very very rich
  • 2esoteric
  • Oct 31, 2025
Fox 5.0 Mustang Tech Oct 31, 2025
