do I have to fix the code 67 koeo before I can run koer sequence? It will not flash any codes koer only the throttle drop that I think is egr related.
I had the clutch pushed down when I ran both tests.
I read instructions that the brake had to be applied and to turn the wheel half turn when runnin koer test, did that, no joy. no codes, nadda, nothing. Original computer was not giving codes koeo at all so changed it to a9l I had lay'n around and drove it around for a month or so.
It also give me a 95 koeo code that is fuel pump circuit/ pcm to motor ground related.
I think I may send my original computer out to be looked at.
no wiring mods/cuts or spices
89 gt 5spd owned for 13+ years
