Sorry for the length, but I want to include everything for your expertise/opinions.
Went to storage yesterday to get the stang out for spring. Brought my booster pack with me, as the battery wasn't trickle charged and might not have had enough juice. Go to start the car, volt gauge (stock) reads well below it's usual, I hear the fuel pump prime, no crank nothing. Put on the booster pack, fuel pump primes again, but no crank. I turn the headlights on, couldn't tell if they were lit fully as it was daylight/glare, try to start the car they didn't dim at least.
I figure this ol battery's had it, leave the storage to buy a new battery (got it tested in store, 12.97v). Get the new battery in, again same thing, primes, no crank, headlights constant power. So me, up in the boonies, checked a few things I could think of; no water or dampness under the dizzy cap, plug #1 not fouled or wet, grounds appeared ok, battery cables showing age but clean and no corrosion on them. Still obviously the car wouldn't start, and got it towed home where I could look at it more today and do research. I've killed the battery before, but not once in three years has the car not cranked over, so I wasn't familiar with all the tricks and checks.
I read jrichker's no crank checklist (not his cranks but won't start version) and moved on to the solenoid tests. Jumpered the big lugs, sparked and the starter kicked over, tested the small lug and jumped it with the big lug and the starter was clicking away. To my understanding this meant the starter, solenoid, and power wiring was functional. I then put the key to on (admittedly I did not check to see if the car would start on it's own), and jumpered the big lugs again and voila the car fired right up without hesitation. Drove the car around the block to see if it would stall out or try to, and to my suprise it seemed to have more oomph then ever before
. The volt gauge (though stock yes I know) was at it's highest and most stable reading, turned the heater on full blast, headlights on, and it barely moved the gauge (with the old battery it would drop right to the middle, or a tad below).
Now the car is starting up problem free with the key. I talked to a buddy mechanic and his thoughts were the starter had seized up over the winter, or the starter is possibly starting to go. I plan on replacing the battery cables (they are the crappy two stud on top design) anyways, and am doing a 3G alternator upgrade and it's associated ground wire increase. Was thinking of letting the car sit for a week as it's just the weekend toy, and see if it starts in a weeks time. What do you guys think, just a seized up starter and I'll probably be fine, or should I do some more tests (lost my multimeter so I didn't get readings of anything)?
P.S. Electrics are not my speciality, try to be clear for me
. The volt gauge (though stock yes I know) was at it's highest and most stable reading, turned the heater on full blast, headlights on, and it barely moved the gauge (with the old battery it would drop right to the middle, or a tad below).Now the car is starting up problem free with the key. I talked to a buddy mechanic and his thoughts were the starter had seized up over the winter, or the starter is possibly starting to go. I plan on replacing the battery cables (they are the crappy two stud on top design) anyways, and am doing a 3G alternator upgrade and it's associated ground wire increase. Was thinking of letting the car sit for a week as it's just the weekend toy, and see if it starts in a weeks time. What do you guys think, just a seized up starter and I'll probably be fine, or should I do some more tests (lost my multimeter so I didn't get readings of anything)?
