okay i used a pulse injector tester and i got nothing. i have power to the fuel pump relay on some of the legs, but the fuel pump doesnt come on. i can jump it at the relay from one leg to another and get the pump to work, but im at the conclusion that the ECU that i bought may be bad. go figure i bought it off ebay. im in hope that maybe a ground is loose or something so if you have any insight please help.
I just installed a new harness and a used ecu (A9L)
my car is a 91 302 Gt HO 5 spd.
the reason i replaced all of that is because some punk stole my computer and hacked my harnesses to pieces.
I replaced the harness and fixed the dash harness with a new pigtail. ive checked just about every fuseable link i could find and i replaced both the fuel pump relay under the seat and the ECC relay. i even tride jumping the fuel pump through the test connector under the hood but that also tested with no results. i have power from the coil and out of the dist.
if you need any information to help me dont hesitate to ask. thank you all!
