No fuel pump sound
red ink
746
Arizona
So whats my problem guys? My car just died outta nowhere on the freeway and it just cranks over and over (as long as there is charge in the battery). But it dosent make the fuel primming sound it normaly does when you turn the key to the on position. any help?
Seems to me there is a fuse for the pump in the under hood fuse box. Otherwise, I would check the inertia switch and then the CCRM.
Good luck.
I would check fule pump fuses, connections around the pump, the inertia switch...
Basically as Striped says when a fuel pump is on it's way out 90+% of the time it gets louder before it dies... So if it didn't get loud check for power to it...
Probably a bad pump. But check everthing first before diving into the tank. It may be a simple fix. The fuel pump relay is in the Constant Control Relay Module (CCRM) located in the bracket with the antifreeze overflow tank. Let us know how it works out. Peace
