This is just one of many problems with my 89'. Let me start off that every now and then, I use to have problems with my headlights at night when I use my turn signal switch, they would turn off. BUT, they would come on if I wiggle the turn signal lever and wouldn't have a problem for a while. Figure it did not have a good contact.
Fast forward to a few weeks ago. Upon turn on my headlights, nothing happen. Parking lamps are on, but now High or Low beams. YET, the headlights come on when I pull the lever towards me for the "passing" function.
So I ordered the turn signal switch repair wiring harness from 5.0Resto that plugs into the multifuction switch. I had to rewire a few things, but manange, connected it, and check to see if my headlights work and nothing. BTW, done this today.
So I went online and ordered the turn signal Lever assembly since mine has some play in it, hence why I can wiggle it around. Now I'm hoping this will work. I forgot to mention, I checked the headlight switch and I'm getting power on all the terminals for headlights, parking lights, fogs, etc. So I scratch the idea of it being my headlight switch.
Anyone ever had a problem with their turn signal lever having some play in it and causing problems with your headlights??
This is just one of my little problems I have with the 89' right now. Waiting on my driver side door lock actuator to come in(Had problems not being able to open the driver side door from the inside/outside), putting on a new hatch striker because the plastic broke on the original and it takes me like 4-5 tries to close the hatch.
