did you check your switches ? and not to be smart but was this "new" actuator tested and confirm it functions? You never know it could be as simple as that. If you have a DVOM or test light confirm that there is battery voltage at the connector if you havent already, then return results for everyone to help you out. Keep the post alive Im sure your not the only one with this problem. Ford wiring is somewhat frustrating at times
