- Jul 25, 2005
- 578
- 0
- 0
Orange04BOSS said:U Know Once U Unbolt The Catback You Lose Alot Of Power Unless You Have Like 600hp. I Ran Open Hpipe For A Day To See What Difference It Makes And It Make A Whole Bunch. Lost Alot Of Power And I Had Nothing In Second Gear. I Did This To My Stock 93 Cobra. It Was Loud But Not Worth It. Specially When U Pull Up Next To A Cop And You Are At A Red Light. Trying To Pull Away From The Light And Be Quiet Is Hard. Trust Me.
by the Caps Lock filtertomustang said:anyway, if your too lazy to install the mufflers won't you be too lazy to install the x-pipe?
yeah but i've welded up muffs faster than i removed that damn passenger side header-to-midpipe bolt. You might get lucky and not be as tight thoughponysarepretty said:mufflers need to be welded in and taken to be the shop, x pipe is just bolt on isn't it?
tomustang said:yeah but i've welded up muffs faster than i removed that damn passenger side header-to-midpipe bolt. You might get lucky and not be as tight though![]()
mustangman9812 said:If you buy a off-road midpipe put at least 1 cat back on each side or get a catted midpipe b/c your car will run better with backpressure. I am putting a cat back on each side of my off-road h-pipe soon!!
