no posi?
  • Thread starter Thread starter 87Mustang351
  • Start date Start date Sep 17, 2006
87Mustang351
220
Canada, Nova scotia, Cape Breton
Sep 17, 2006
  • Sep 17, 2006
hey guys my mustang just started doing this 4:10 SVO gears a few years old, i went to do a dognut where i ahd done many before and only one wheel it spinning now and it wont swing around, only thing i have done to the car is remove the sway bar and i cant see that not letting both wheels spin, any ideas guys?
89white50
440
central MA
Sep 17, 2006
  • Sep 17, 2006
time to rebuild the trac-lok, you have toasted the clutch packs. spend the 35 bucks for a rebuild kit and bring it to a shop. since your rebuilding it you might have to reshim the carrier, thats why i say bring it to a shop.
87Mustang351
220
Sep 17, 2006
  • Sep 17, 2006
alright man thanks alot
86bluecobra
Advanced Member
Dec 20, 2004
4,265
12
69
B.C. Canada
Sep 17, 2006
  • Sep 17, 2006
Never nice to lose 1 leg. Simple to rebuild and if you have a few tool to measure with it can easily be done at home.
JChalfan
551
Bellevue, WA
Sep 18, 2006
  • Sep 18, 2006
The clutch replacement is pretty easy. I didn't know that you could need to reshim the carrier after you did it. I've done it on one 7.5" by myself, and I helped my friend do it in my current 8.8" when he put new gears in.
I think Summit sells the rebuilt kits.
It'll be nice to have the other leg back.
Jeff
blackened88lx
Connecticut
Sep 18, 2006
  • Sep 18, 2006
Your clutches might be fine. Which direction are you trying to do the donuts in, to the left? or to the right? The rotation of the driveshaft twists the rearend to the left, taking weight off the right rear, and this is why most non-posi cars will spin the right rear tire. If you removed your sway bar, when you go to whip a donut to the right, it's allowing more body roll and taking even more weight off that tire, and it will overcome the posi very easily, even with perfectly good clutches. Try doing a donut to the left if you aren't already. I'm not saying your clutches are not gone, but if it will spin a nice posi in a straight line, this is most likely what's happening. If you want it to spin posi all the time, get a detroit locker or a good aftermarket posi unit.
myslo50
247
ohio
Sep 18, 2006
  • Sep 18, 2006
i wouldnt even attempt to replace the discs in the trac-lock. there junk. buy a aburn or a eaton POSI unit and do it right. i had my kit rebuilt this past feburary and blew the clutches out in a month. i wish i would have bought a actual posi unit. trac-lock is like a limited slip.
D
Electrical Weird door wiring issues
  • Dakar09
  • Oct 20, 2026
Dakar09
D
  • 2000xp8
  • Jul 9, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 18, 2026
AeroCoupe
Rear Disc and Rims Offsets
  • TripleYellow
  • Nov 11, 2025
2K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jan 9, 2026
TripleYellow
G
In expensive ceramic coating
  • gray owl
  • Jul 12, 2026
  • Mustang Sound & Shine All
Mustang Sound & Shine All Aug 18, 2026
NotaVegetarian
N
Progress Thread Sask84gt's 84 GT - Questions and Progress Thread
  • Sask84gt
  • Oct 13, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jun 6, 2026
Sask84gt
