No Power Out Of The Hole
  • Thread starter Thread starter BigE85
  • Start date Start date Mar 13, 2017
1 of 2 Next Last
BigE85
28
Kansas
Mar 13, 2017
  • Mar 13, 2017
Hey guys don't know if anyone has post this before so forgive me. But I could not find a clear answer. The problem I have on my 94 gt is when I lay into it from a dead stop it's lacks power bad. But if I just drive it nice and slow it runs great. Idles great no misfire or back fire. I did a full tune up oil,plugs,wires,fuel filter new distributor not reman new put a new tfi module.New Cold air intake cleaned all sensors iac and mas. I did check for codes I was pulling a 172 and 176 which I'm getting ready to change o2 sensors so Im at total lost. Timing is set at between 12 to 14 I do have 93 octane in it. Best way to explain it is from a dead stop to go it's like a surge of no power then is fine it's a stock motor except for the cold intake and flow master exhaust.
General karthief
20+ Year Stangneter
Aug 25, 2016
27,945
10,584
203
polk county florida
Mar 13, 2017
  • Mar 13, 2017
How many miles, stick or auto?
BigE85
28
Kansas
Mar 13, 2017
  • Mar 13, 2017
122k 5 speed manual
General karthief
20+ Year Stangneter
Aug 25, 2016
27,945
10,584
203
polk county florida
Mar 13, 2017
  • Mar 13, 2017
Fuel pressure?
BigE85
28
Kansas
Mar 13, 2017
  • Mar 13, 2017
Right at 32psi at idle and holds there never drops below that.
BigE85
28
Kansas
Mar 13, 2017
  • Mar 13, 2017
General karthief
20+ Year Stangneter
Aug 25, 2016
27,945
10,584
203
polk county florida
Mar 14, 2017
  • Mar 14, 2017
What gear ratio, rear tire size.
BigE85
28
Kansas
Mar 14, 2017
  • Mar 14, 2017
Everything is stock not sure what gears it has what ever a stock 94 gt has but tires are the stock 245/45/R17
General karthief
20+ Year Stangneter
Aug 25, 2016
27,945
10,584
203
polk county florida
Mar 14, 2017
  • Mar 14, 2017
This question is relative to certain factors,
Your door tag should have a axle ratio code and the weight of the car, start with that and do a compression test on the engine, this info will give you a starting point.
If your engine is in good shape and no clutch problems I would look at a gear change, at least a 3:55 gear with stock tires will make it responsive starting out.
Show a pick of your engine compartment.
Keep in mind if you are comparing your car to newer versions like a 2010 and up your ride is gonna feel like a dump truck.
Admin Dude
Jan 4, 1985
43,134
21,305
234
Box behind Walmart
Mar 14, 2017
#10
  • Mar 14, 2017
  • #10
I would spend some time locating the vacuum leak before tossing brand new sensors in there. They will still read lean.
FoxMustangLvr
I love my Pimp
SN Certified Technician
Oct 14, 2012
4,968
3,514
204
Spokane, Wa
Mar 14, 2017
#11
  • Mar 14, 2017
  • #11
I thought fuel pressure was supposed to be about 39 psi? Is it different for a 94'? I don't think gears are your problem, however, they are a nice upgrade. Dumping the clutch from a dig, even with stock gears, is still a lot of fun and there should be no problem with acceleration. Search for a vacuum leak, fix the O2 sensors, recheck codes and take it for a drive. Do you have cats? When they start clogging up you start to lose power too.
BigE85
28
Kansas
Mar 14, 2017
#12
  • Mar 14, 2017
  • #12
Thanks guys. I will definitely look at this when I got the car I replaced a bunch of vaccum lines. I'll double check them I agree I don't think I have a clutch or gear problem. It feels more like a fuel problem alot of hesitation if going to lay into it bogs down but if I drive it normal it's fine shifts fine. It seems like a fuel or timing but not sure. But I can be in 4th gear and the car pulls good. No hesitation. If I put a fuel gauge on it and I'm reading 32 psi when I rev the car what should the fuel pressure go up to cause.
BigE85
28
Kansas
Mar 14, 2017
#13
  • Mar 14, 2017
  • #13
Sorry I forgot I have no cats on this car. Its been like that since 94 it was a one owner car and has been stock all its life. Except the exuast but the pervious owner never had any problems like this. The only other thing was when I put the fuel pressure gauge on it the fuel pressure never drop below 32 psi. but when Rev up fuel pressure went up to like 39psi and drop fast but not below 32 psi. Is this a fuel pump issue or is it a mas sensor not reading right due to the cold intake messing with the air and fuel.
Admin Dude
Jan 4, 1985
43,134
21,305
234
Box behind Walmart
Mar 14, 2017
#14
  • Mar 14, 2017
  • #14
Your codes indicate that both banks are lean. That's a pretty good indication that you're getting unmetered air from somewhere.
If your car has been running in this condition for some time, it's also a pretty good bet that the additional heat has taken it's toll on the tired O2 sensors. Try finding the leak before you replace them. It could be any number of gaskets and seals or hoses.
If you have an adjustable fuel pressure regulator, consider swapping it out for an OEM piece. If you have the original OEM piece, consider replacing it.
Don't neglect the possibility that the fuel pump may also be at fault. If it's original, it likely time for a replacement. There are very few situations that require an adjustable unit. You do not appear to have those conditions and in some cases, adjustable regulators just provide another avenue of error. A mechanical fuel pressure gauge while you drive would help rule out fuel issues. The smell of gas in the vacuum line going to fuel regulator is a sign of a failing regulator.
Reactions: RangerJoe and FoxMustangLvr
FoxMustangLvr
I love my Pimp
Oct 14, 2012
4,968
3,514
204
Spokane, Wa
Mar 14, 2017
#15
  • Mar 14, 2017
  • #15
@jrichker
Should fuel be 39psi for a 1994?
jrichker
StangNet's favorite TOOL
Mar 10, 2000
27,512
2,813
234
Dublin GA
Mar 14, 2017
#16
  • Mar 14, 2017
  • #16
FoxMustangLvr said:
@jrichker
Yes
Check fuel pressure:
The local auto parts store may rent or loan a fuel pressure test gauge if you don't have one.
Disconnect the vacuum line from the fuel pressure regulator. Check it for evidence of fuel present in the line by removing it and blowing air through it. If you find fuel, the fuel pressure regulator has failed. Reinstall the line; leave the fuel pressure regulator end of the vacuum line disconnected. Then cap or plug the open end of the vacuum line and stow it out of the way.
Connect the fuel pressure test gauge to the Schrader port located just behind the alternator.
Turn the ignition switch on & start the engine. Observe the pressure: you should see 37-41 PSI at idle.
Turn the ignition off; reconnect the vacuum line to the fuel pressure regulator. Then disconnect the fuel pressure test gauge. Watch out for squirting gas when you do this.
Reactions: FoxMustangLvr
BigE85
28
Kansas
Mar 14, 2017
#17
  • Mar 14, 2017
  • #17
Ok thanks. i will look over this tonight I did check the regulator for fuel none was presence. Will double check for leaks and go from there. Fuel pump is the original to my knowledge so will be looking at that. Did check fuel pressure and was holding at 32psi
BigE85
28
Kansas
Mar 16, 2017
#18
  • Mar 16, 2017
  • #18
Hey guys wanted to give you a update. Change some more vaccum lines just to be on the safe side. Change the intake manifold gaskets and the fuel pressure regulator. Put new o2 sensor and recheck timing. Started it up took it for drive same thing so I took the cold air intake off and put the stock back on. And it was a total diffrent car. Guess the stock maf can't read that much air so I'll have to upgrade but thanks for your guys help.
Reactions: FoxMustangLvr and 5.0Droptop
General karthief
20+ Year Stangneter
Aug 25, 2016
27,945
10,584
203
polk county florida
Mar 17, 2017
#19
  • Mar 17, 2017
  • #19
I never thought that, what cai you got? Pics?
D
Dart68
87
22
18
Mar 17, 2017
#20
  • Mar 17, 2017
  • #20
It might not be that the MAF can't read that much air but that the air it's trying to read doesn't flow correctly into the MAF. That the air flow is disturbed. I've read that this is a problem with some aftermarket cold air ducts.
Reactions: RangerJoe and Noobz347
1 of 2 Next Last
C
Engine Idle cuts out
  • claypoolxx
  • Mar 7, 2026
Fox 5.0 Mustang Tech Jul 24, 2026
alutwon
T
First Car, what should I do for power??
  • tunedV6
  • Apr 13, 2026
1996 - 2004 SN95 Mustang -General/Talk- May 4, 2026
580HP*428Cj
Fox '87 GT can't get to stay running
  • spilly
  • Mar 29, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jun 20, 2026
spilly
A
95 Gt intermittent backfire
  • A_A_Ron
  • May 26, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- May 26, 2025
A_A_Ron
A
Dies at start up, mild surge
  • Dontknowchit
  • May 15, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jun 9, 2025
