no power to fusebox for radio fuse
f8tlfiveo
My wife likes my spool and blow-off valve.
Aug 8, 2007
1,585
102
64
Lancaster, PA
i did some searching and came up empty handed.. my brothers car is a 93 gt the radio just stopped working..checked fuses..they are all good.. turned ignition on and checked both sides of every fuse and the spot where the radio fuse is gets no power to either side. obviously somthing before the fusebox is stopping the power before it gets to the fuse box..i am good with mechanical issues..but the electrical stuff is not my forte..any help would be greatly appreciated.
MustangLX-5.0
858
Lehigh Acres Fla.
Does the horn and cigarette lighter also not work? Might be something in the ignition switch, or a wire that goes from the ignition switch to the fuse box. Are you sure there is no power at the fuse? Did you pull the fuse and check for a voltage at either of the terminals?
