no spark please help!!
joebeez
15
utah
k i just got my 5.0 ho motor back together and i am not getting spark from any of the plug wires. i took my module to autozone and had it tested, everything looked good. so i jsut decided to get a new distributer. for one the distrubter is about 1cm shy of sliding down into the motor. for two before we replaced that we were getting spark from the coil, but now out of any plug wires. any ideas? 1 about the distributer not sliding in all the way, and two the no spark issue. thx
check the soleniod........................batt .........wires........................cap..................dizzy...............the problem is right in front of you..................make sure you have a good hot/ground.................ignition problems are so easy to fix............
i had these same promblems a couple weeks back when i put my motor in for the first time...as for the distributor, try wigglin/man handling it, its got to slide onto gears down there and sometimes the oil pump shaft will get in the way...as for no spark, i went through the same thing, no spark what so ever, but i put a big fat ground on, and she fired right up...also do a search for this, sum 1 in one of my threads(i posted the same question) had a list of things to check, im jus too lazy too look it up...good luck man :nice:
i put it to top dead center. and i checked the rotor. i am geting spark from the coil, but none from the spark plug wires. the batery is grounded extreemly well, correct me if im wrong but there are only 2 wires that go to the cool, the red and green wires...right. this is a 1983 mustang gt ho, btw. iand i have the firing order correct for the 5.0 ho
Slide the dist. i as far as it will go and then (with the cap off) turn the rotor to the left or right until it drops in the rest of the way. Did the new dist come with a new cap and rotor? Cuy I bet your problem has something to do with that and not so much the mechanical aspect of the dist. Also, if it still does not fit in all the way, double check to make sure its the right one, cuz if its for a different car then the shaft might be longer... :shrug:
Cranks OK, but No Start Checklist for Fuel Injected Mustangs
1.) Remove push on connector from starter solenoid and turn ignition switch on. Place car in neutral or Park. Remove coil wire from distributor & and hold 3/8” away from engine block. Jumper the screw to the big bolt on the starter solenoid that has the battery wire connected to it. You should get a nice fat blue spark.
A.) Coil
B.) TFI module
C.) PIP sensor in distributor
D.) ECC relay next to computer - look for 12 volts at the fuel injector red wires
E.) Fuse links in wiring harness - look for 12 volts at the fuel injector red wires
F.) Ignition switch - look for 12 volts at the ignition coil red/lt green wire.
G.) Computer
2.) Spark at coil wire, pull #1 plug wire off at the spark plug and check to see spark. No spark, possible failed items in order of their probability:
B.) Distributor cap
C.) Rotor
D.) Spark Plug wires
Two reasons:
Clue – listen for the fuel pump to prime when you first turn the ignition switch on. It should run for 5-20 seconds and shut off. To trick the fuel pump into running, find the ECC test connector and jump the connector in the lower RH corner to ground. See http://www.mustangworks.com/articles/electronics/eec-iv_codes.html for a description of the test connector. If the relay & inertia switch are OK, you will have power to the pump. Check fuel pressure – remove the cap from the schrader valve behind the alternator and depress the core. Fuel should squirt out, catch it in a rag. Beware of fire hazard when you do this. In pinch you can use a tire pressure gauge to measure the fuel pressure. It may not be completely accurate, but you will have some clue as to how much pressure you have.
No fuel pressure, possible failed items in order of their probability:
C.) Clogged fuel filter
D.) Failed fuel pump
E.) Blown fuse link in wiring harness. Look for 12 volts at the Orange/Lt Blue wire on the fuel pump relay
F.) Fuel pressure regulator failed. Remove vacuum line from regulator and inspect for fuel escaping while pump is running.
Fuel pressure OK, the injectors are not firing.
A.) A Noid light available from Autozone, is one way to test the injector wiring.
B.) I like to use an old injector with compressed air applied to the injector where the fuel rail would normally connect. I hook the whole thing up, apply compressed air to the injector and stick it in a paper cup of soapy water. When the engine cranks with the ignition switch on, if the injector fires, it makes bubbles. Cheap if you have the stuff laying around, and works good too.
a.) Pull an injector wire connector off and look for 12 volts on the red wire when the ignition switch is on.
b.) No power, then look for problems with the 10 pin connecter (salt & pepper shakers at the rear of the upper manifold).
c.) No power and the 10 pin connections are good: look for broken wiring between the orange/black wire on the ECC relay and the red wire for the 10 pin connectors.
4.) Spark & fuel pressure OK.
A.) Failed IAB (no airflow to start engine). Press the throttle ¼ way down and try to start the car.
C.) Engine ignition or cam timing off: only likely if the engine has been worked on recently).
joebeez said:
what does 180 out mean?
it means the dizzy is out of phase by 180*. the dizzy was not stabbed in on the compression stroke.
bmorrisj means he forgets to install the spout connector, i believe. hard to time a car with the TFI disconnected. :)
you cam advance is not related to ignition timing (it affects bottom end performance, as im sure you know - why you did it).
