No spark where? Does the coil spark? Does the dizzy spark? Does each of the points spark? Does each wire spark? You gotta just keep going down the line.
Ignition module. It's in a heat sink under the air box and you will need a special tool to remove it. Take it to most parts stores and they can test it for you. If it tests good then look towards the internals of the dist they may be causing problems. My stock one locked up at 80K miles.
