no spark
93PONY
219
pensylvania
i have no spark in my 93 2.3, i have replaced the crank sensor, ignition control modual, all the plugs and wires, and i have nothing. i can put a screwdriver in the plug wire and the is no arc. what else can cause this?
you might have to replace your ignition coil I had the same problem after changing all the same parts,I ended up buying another ignition coil
the 93 doesnt have a coil, it uses 2 coil packs, I would have your ign module tested, they dont always work out of the box, i would also pick up some junkyard coil packs and swap those on. Then start checking wires, you might have a short somewhere, or a bad computer... Does it spit out any codes? Did you make sure and get the separate 3rd wire on the crank sensor hooked up?
Dr.
