no spark
  • Thread starter Thread starter sicstang
  • Start date Start date May 16, 2009
  • 3
1 of 3 Next Last
sicstang
51
Valdosta Georiga
May 16, 2009
  • May 16, 2009
okay i got a 87 mustang gt that hasn't started in about a year. i finally got the wiring fixed so the fuel pump works so now i have fuel and the engine will turn over strong all day but i have zero spark. i do have 12 volts going in to my coil. any help would be greatly appreciated.
jrichker
StangNet's favorite TOOL
Mar 10, 2000
27,512
2,813
234
Dublin GA
May 16, 2009
  • May 16, 2009
No 12 volts at coil: start with item 1G on the checklist...
Cranks OK, but No Start Checklist for Fuel Injected Mustangs
A word about this checklist before you start: it is arranged in a specific order to put the most likely failure items first. That will save you time, energy and money. Start at the top of the list and work your way down. Jumping around will possibly cause you to miss just what you need to see to find and fix the problem. Don’t skip any steps because the next step depends on the last step working correctly.
Revised 22-Mar-2009 to change links for electrical diagrams
1.) Remove push on connector (small red/blue wire) from starter solenoid and turn ignition switch on. Place car in neutral or Park and set the parking brake. Remove the coil wire from distributor & and hold it 3/8” away from the engine block. Jumper the screw to the big bolt on the starter solenoid that has the battery wire connected to it. You should get a nice fat blue spark.
A.) MSD or Crane ignition box if so equipped
B.) TFI module: use a test light to check the TFI module. Place one lead of the test light on the red/green wire on the ignition coil connector and the other lead on the dark green/yellow wire on the ignition coil connector. If the TFI is working properly, the test light will flash when the engine is cranked using the ignition switch.
C.) Coil
D.) PIP sensor in distributor. The PIP sensor supplies the timing pulse to trigger the TFI and injectors. See paragraph 5A - a noid light will tell if the pip is working by flashing when the engine is cranking.
E.) No ECC or computer power - ECC or computer relay failure
86-93 models only: ECC relay next to computer - look for 12 volts at the fuel injector red wires
F.) No ECC or computer power - fuse or fuse link failure
86-93 models only: Fuse links in wiring harness - look for 12 volts at the fuel injector red wires. All the fuse links live in a bundle up near the starter solenoid.
G.) Ignition switch - look for 12 volts at the ignition coil red/lt green wire. No 12 volts, blown fuse link or faulty ignition switch. Remove the plastic from around the ignition switch and look for 12 volts on the red/green wire with the switch in the Run position. No 12 volts and the ignition switch is faulty. If 12 volts is present in the Run position, then the fuse or fuse link is blown.
Note: fuses or fuse links blow for a reason. Don’t replace either a fuse or fuse link with one with a larger rating than stock. Doing so invites an electrical fire.
Ignition fuse links may be replaced with an inline fuse holder and 5 amp fuse for troubleshooting purposes.
H.) Missing or loose computer power ground. The computer has its own dedicated power ground that comes off the ground pigtail on the battery ground wire. Due to it's proximity to the battery, it may become corroded by acid fumes from the battery. It is a black cylinder about 2 1/2" long by 1" diameter with a black/lt green wire. You'll find it up next to the starter solenoid where the wire goes into the wiring harness
I.) Computer.
J.) Bad or missing secondary power ground. It is located between the back of the intake manifold and the driver's side firewall. It supplies ground for the alternator, A/C compressor clutch and other electrical accessories such as the gauges.
K.) Engine fires briefly, but dies immediately when the key is released to the Run position. Crank the engine & when it fires off, pull the small push on connector (red wire) off the starter relay (Looks like it is stuck on a screw). Hold the switch in the crank position: if it continues to run there is a problem with either the ignition switch or TFI module. Check for 12 volts at the red/green wire on the coil with the switch in the Run position. Good 12 volts, then replace the TFI. No 12 volts, replace the ignition switch.
Wiring Diagrams:]/b]…
Sorry, the AutoZone wiring diagram links no longer work. You can navigate to the diagrams yourself via AutoZone.com | Repair Info and select the car year, make, model and engine. That will enable you to bring up the wiring diagram for your particular car.
See the following website for some help from Tmoss (diagram designer) & Stang&2Birds (website host) for help on 88-95 wiring Mustang FAQ - Engine Information Everyone should bookmark this site.
Ignition switch wiring
Complete computer, actuator & sensor wiring diagram for 91-93 Mass Air Mustangs
http://www.veryuseful.com/mustang/tech/engine/images/91-93_5.0_EEC_Wiring_Diagram.gif
Complete computer, actuator & sensor wiring diagram for94-95 Mass Air Mustangs
http://www.veryuseful.com/mustang/tech/engine/images/94-95_5.0_EEC_Wiring_Diagram.gif
2.) Spark at coil wire, pull #1 plug wire off at the spark plug and check to see spark. No spark, possible failed items in order of their probability:
B.) Distributor cap
C.) Rotor
D.) Spark Plug wires
Two reasons:
Clue – listen for the fuel pump to prime when you first turn the ignition switch on. It should run for 5-20 seconds and shut off. To trick the fuel pump into running, find the EEC test connector and jump the connector in the Upper RH corner to ground. The EEC connector is near the wiper motor and LH hood hinge.
If the relay & inertia switch are OK, you will have power to the pump. Check fuel pressure – remove the cap from the Schrader valve behind the alternator and depress the core. Fuel should squirt out, catch it in a rag. Beware of fire hazard when you do this. In a pinch, you can use a tire pressure gauge to measure the fuel pressure. It may not be completely accurate, but you will have some clue as to how much pressure you have. If you have any doubts about having sufficient fuel flow/pressure, rent a fuel pressure test gauge from the auto parts store. That will tell you for sure if you have adequate fuel pressure.
C.) Clogged fuel filter
D.) Failed fuel pump
A.) A noid light available from any auto parts store, is one way to test the injector wiring.
The noid light plugs into the fuel injector harness in place of any easily accessible injector. Plug it in and it will flash if the injector is firing.
B.) I like to use an old injector with compressed air applied to the injector where the fuel rail would normally connect. I hook the whole thing up, apply compressed air to the injector and stick it in a paper cup of soapy water. When the engine cranks with the ignition switch on, if the injector fires, it makes bubbles. Cheap if you have the stuff laying around, and works good too.
D.) Pull an injector wire connector off and look for 12 volts on the red wire when the ignition switch is on.
E.) No power, then look for problems with the 10 pin connecter (salt & pepper shakers at the rear of the upper manifold).
F.) No power and the 10 pin connections are good: look for broken wiring between the orange/black wire on the ECC relay and the red wire for the 10 pin connectors.
G.) TPS voltage exceeds 3.7 volts with the throttle closed. This will shut off the injectors, since the computer uses this strategy to clear a flooded engine. Use a DVM, a pair of safety pins, and probe the black/white and green wires to measure the TPS voltage.
It should be .5-.99 volts with the key on, engine not running. Note that if the black/white wire (signal ground) has a bad connection, you will get some strange readings. Make a second measurement using the battery post as the ground to eliminate any ground problems. If the readings are different by more than 5%, you may have a high resistance condition in the black/white signal ground circuit.
6.) Spark & fuel pressure OK.
A.) Failed IAB or improperly set base idle (no airflow to start engine). Press the throttle ¼ way down and try to start the car. See the "Surging Idle Checklist for help with all your idle/stall problems.
C.) Engine ignition or cam timing off: only likely if the engine has been worked on recently).
HO & 351W 1-3-7-2-6-5-4-8
Non HO 1-5-4-2-6-3-7-8
E.) No start when hot - Press the throttle to the floor & try starting it if you get this far. If it starts, replace the ECT.
sicstang
51
Valdosta Georiga
May 16, 2009
  • May 16, 2009
well i hooked the test ligt to the red and green wire going to coil then put the clip side of the light on the other wire green/yel coming off of coil tried to start it and the light didn't blink so i will replace the tfi tommorrow and let you know what happens thanks for the help i hope i did that test right.
jrichker
Mar 10, 2000
27,512
2,813
234
Dublin GA
May 17, 2009
  • May 17, 2009
Check the PIP signal using a noid light (step 1D and 5A) before replacing the TFI. This will make sure that you don't have a bad PIP sensor.
sicstang
51
Valdosta Georiga
May 17, 2009
  • May 17, 2009
okay well i replaced the tfi module before i got your last post and still the same thing nothing. i will buy a noid light tommorrow and check the injectors. i can't thank you enough for all your help like i said this thing hasn't ran in a year. i will let you know what happens tommorrow.
sicstang
51
Valdosta Georiga
May 17, 2009
  • May 17, 2009
TFI module replaced there is still no spark coming out of plug wires.
hotcobra03
poteet,tx
May 17, 2009
  • May 17, 2009
spark?
is no spark a result of test in step 1 or step 2?
sicstang
51
Valdosta Georiga
May 18, 2009
  • May 18, 2009
step 1 no spark
sicstang
51
Valdosta Georiga
May 18, 2009
  • May 18, 2009
replaced coil no change. is the positive and negative side of the coil suppose to have 12 volts? i ask cause mine does and i would think the negative side would be a ground.
jrichker
Mar 10, 2000
27,512
2,813
234
Dublin GA
May 18, 2009
#10
  • May 18, 2009
  • #10
The TFI provides a ground for the coil. Without a ground you will see 12 volts on both sides of the coil. With a ground, you will see 12 volts on the red/green wire and less than 1 volt on the tan/yellow wire.
How the TFI ignition works in 86-93 model Mustangs:
Tools needed: DVM, noid light, safety pin.
Theory of operation:
The TFI ignition in 86-93 Mustangs has 4 main components: the ignition switch, the coil,
the TFI module and the PIP sensor inside the distributor.
The ignition switch gets power from the two yellow wires that are supplied power
by a fuse link located in the wiring harness that connects to the starter solenoid.
The coil is mounted on the driver’s side strut tower on most EFI Mustangs. It gets power
from a red/green wire and a brown/pink wire from the ignition switch. That wire from
the ignition switch feeds a 20 gauge blue fuse link that connects to the red/green wire.
The fuse link protects the wiring and the ignition switch, since the fuse link for the two yellow
power supply wires has a much higher current rating. Without the smaller fuse link protecting
the smaller wiring used in the ignition circuit, a short there would cause the red/green wire
to overheat and burn up.
The TFI module is mounted on the side of the distributor and supplies the ground for the coil.
Every automotive power supply circuit uses the ground as the return path to carry power back
to the negative side of the battery.
The TFI switches the tan/yellow wire coming from the coil
to ground. It gets power from the red/green wire when the ignition switch is in the Run position.
The red/lt blue wire supplies a signal to turn on more power (dwell time) when the engine is cranking.
The trigger signal comes from the PIP sensor when cranking and the computer when the
engine is running. The SPOUT jumper plug enables computer controlled spark advance.
When the SPOUT is removed, spark advance is locked at the setting determined by the
mechanical position of the distributor.
The PIP sensor is in the bottom of the distributor under the shutter wheel. It is a Hall effect
magnetic sensor that senses a change in the magnetic field when one of the slots in the
shutter wheel uncovers the sensor. Then it supplies a pulse that triggers the TFI module
to provide a ground to the ignition coil. A bad PIP will often set code 14 in the computer and
cause hot start problems. Replacing the PIP sensor requires removal of the distributor and pressing
the gear off the distributor shaft to expose the sensor. For most people, a remanufactured
distributor ($55-$75) is the solution, since they may not have access to a press.
Troubleshooting the ignition system – no spark or weak spark. All the tests are done with
the ignition switch in the Run position unless specified otherwise. A safety pin may be used
to probe the wiring connectors from the back side.
1.) Check for 12 volts at the yellow wires on the ignition switch. No 12 volts and
the fuse link near the starter solenoid has open circuited.
2.) Check for 12 volts on the red/green and brown/pink wires coming out of the ignition switch.
3.) Check for 12 volts at the ignition coil. No 12 volts and the blue 20 gauge fuse link has open circuited.
4.) Check for 12 volts at the red/green wire on the TFI module. No 12 volts and you have wiring problems.
5.) Remove the small red/blue wire from the starter solenoid (looks like it is stuck on a screw).
This is a safety measure to keep the engine from turning while you are making measurements.
Have a helper turn the ignition switch to Start and look for 12 volts on the red/lt blue wire on the TFI module.
No 12 volts and you will have starting problems, but push starting the car will work OK. No 12 volts,
replace the ignition switch. Be sure to reconnect the red/blue wire to the starter when you finish.
6.) A noid light available from any auto parts store, is one way to test the PIP pulse. The computer uses
the PIP signal to trigger the fuel injectors. The noid light plugs into the fuel injector harness in place
of any easily accessible injector. Plug it in and it will flash if the PIP is working. No flash from the
noid light and the PIP is suspect. To confirm the PIP is being the source of the non flashing
noid light, look for 12 volts on the red injector wiring. Good 12 volts and no flashing noid light means the PIP has failed.
7.) Remove the SPOUT plug from the harness and try to start the engine. If it starts,
replace the PIP. This is a common no start condition when the engine is hot.
8.) The TFI module is a go/no go item when you have a no spark/weak spark condition on a cold engine.
It either works or it doesn’t.
The TFI failure mode on a running car is usually a high speed miss on a warm engine. Many auto parts
stores will test your TFI module for free. Bring along a hair dryer to get it hot while testing it and
run several test cycles, since it often gets weak when it heats up.
The coil is somewhat more difficult to pinpoint as a problem. A good coil will make a nice fat blue spark 3/8”-1/2” long.
The problem is that one person’s perception of a fat blue spark looks like may not be accurate enough to spot a weak coil.
The coil is cheap enough ($13-$16) that having a known good working spare might be a good idea.
Vacuum diagram 89-93 Mustangs
HVAC vacuum diagram
TFI module differences & pinout
sicstang
51
Valdosta Georiga
May 18, 2009
#11
  • May 18, 2009
  • #11
i get 12 volts on both sides of the coil so that is right right? okay i have replaced the coil, the tfi module, the distributor the rotor and the cap and i still have no spark i don't know what else to replace.
jrichker
Mar 10, 2000
27,512
2,813
234
Dublin GA
May 18, 2009
#12
  • May 18, 2009
  • #12
Did you get any results with the noid light? You may still have some problems with the PIP sensor or PIP sensor wiring. No PIP pulse, no spark and no injector pulse.
hotcobra03
poteet,tx
May 19, 2009
#13
  • May 19, 2009
  • #13
fuel pump relay
what did you do to fix wiring for pump,,,
Jrichkler is thier a tie with the tfi and the fuel pump relay?
jrichker
Mar 10, 2000
27,512
2,813
234
Dublin GA
May 19, 2009
#14
  • May 19, 2009
  • #14
As you know, the fuel pump runs for 2-5 seconds when you first turn the key on and then it shuts off. The computer looks for a certain minimum number of PIP pulses per second before it turns the fuel pump back on after the original 2-5 second startup run.
hotcobra03
poteet,tx
May 19, 2009
#15
  • May 19, 2009
  • #15
did you try step 5 and 7...
my buddys truck had a problem like yours,,we had no tools and just started changing parts..after the parts like you we were stumped,,,ended up being a loose connection on the nss..he`s truck was an auto so we couldnt push start it''
jrichkler...so than thats a yes to a tie but on the flipside that shouldnt change startup...thought 361 red was fed from fpr/eccrelay
sicstang
51
Valdosta Georiga
May 19, 2009
#16
  • May 19, 2009
  • #16
for number seven what is the spout plug?
sicstang
51
Valdosta Georiga
May 19, 2009
#17
  • May 19, 2009
  • #17
okay i removed the spout and i have spark. still wouldn't start so i sprayed some starter fluid in the intake and she fired for a second but shot flame out of the throttle body so what does that mean? also how do you replace the PIP?
HISSIN50
34
129
May 19, 2009
#18
  • May 19, 2009
  • #18
I can't understand half of what's been said here. But........... if you have solid spark, your PIP should be fine. If you only have spark with the SPOUT connector removed, more testing is needed but that can suggests a bad EEC.
Run the list, being sure that tests are done properly and the correct results are observed.. The coil does not see 12V on both sides. VPWR goes into the side with the + on it, and the TFI sends a ground pulse to the side labeled -
sicstang
51
Valdosta Georiga
May 19, 2009
#19
  • May 19, 2009
  • #19
yes i have spark now with the spout disconnected. with it connected no spark. so seems i need to replace the eec. i redid the timing and now it doesn't backfire. now the fuel issue. my injectors are not firing is this due to the eec as well? I only have .227 volts on the red wires coming off the injectors.
HISSIN50
34
129
May 19, 2009
#20
  • May 19, 2009
  • #20
You have an issue with VPWR reaching the injectors. Each injector should see continuous 12V when the key is on. Before you replace anything, find the source of the wiring issues. Also, because of the lack of power, any noid light testing you did is invalid. Once you restore 12V to the injectors, recheck injector pulse with a noid light.
  • 3
1 of 3 Next Last
N
Engine 86 GT no start/stall
  • nweber
  • Jul 28, 2026
Fox 5.0 Mustang Tech Jul 29, 2026
AeroCoupe
J
Engine Stalling
  • josh40tay
  • Oct 20, 2026
JD1964
  • brandyn200
  • Jun 20, 2026
AeroCoupe
A
1987 5.0 speed density Foxbody crank no start
  • Alan2204
  • May 23, 2026
Fox 5.0 Mustang Tech May 30, 2026
Mcmahst
9
1997 gt Starts then dies a few seconds after.
  • 97orange
  • Aug 13, 2026
  • SN95 4.6L Mustang Tech
SN95 4.6L Mustang Tech Aug 17, 2026
97orange
9
