Engine No start after timing chain replacement??
Probably because you have no compression. Trying to start an interference engine with a broke timing chain will leave you with a mess valve wise. Do a compression check.
As far as the no spark. Check to see if you are getting a pulse from the TFI at the coil. MSD pulses the positive side. Stock ignition pulses the negative side.
The perception of turning over too fast can come from lack of compression.
I hope the previous posts are wrong that you damaged the valvetrain, but that would explain what you are describing. I'd rather have accidentially installed the chain out of time than to find bent valves.
There is no way in hell that he doesn't have at least a few. ( I'd bet,.......Oh........about 16) The noise is definitely compression escaping back into the intake and out the headers. I'll bet the engine is spinning the same speed as it would w/o spark plugs in it.
OP,....sorry to say it again, but you have an engine to remove. OR At the very least, a set of heads to rebuild.
Reactions: toolow91
