the only way i can start my car right now is if i put the key in the on position and then jump the solenoid with a screw driver? i already replaced the ignition switch and the starter solenoid...could my problem be my neutral safety switch? BTW the car is an 88 and a auto....this happened all of a sudden...got it running great went around the block and shut it off in the driveway..went to start it back up and it just clicks...
also i have no brake lights if i push the brake peddle down...if i pull the brake light switch manual it will work but not if i push the brake peddle down...
next question..
my top will not go down..only up....could my switch be bad or is it something more?
thanks!
next question..
thanks!
