E Eric m cormier New Member Aug 21, 2018 1 0 1 Moncton n.b. canada Aug 21, 2018 #1 Aug 21, 2018 #1 2001 gt changed gauge cluster anti theft came on can't start. Car
wmburns SN Certified Technician Aug 14, 2009 5,892 514 204 Houston Texas Aug 21, 2018 #2 Aug 21, 2018 #2 Well.......The anti-theft module is inside the cluster. So if the any of: Cluster PCM Key are changed then PATS reprogramming is needed. It may be possible to swap the PATS daughter board from the old cluster to the new. Here's some information on a possible DIY solution. ForScan ODB2 scanner w ELM327 USB https://www.stangnet.com/mustang-forums/resources/forscan-odb2-scanner-w-elm327-usb.57/
