No tailpipes or dumps
  • Thread starter Thread starter CONCRETEWARFARE
  • Start date Start date May 19, 2007
C
CONCRETEWARFARE
208
NEW YORK
May 19, 2007
  • May 19, 2007
Is there anything wrong with not running tailpipes or dumps off of the back of the mufflers? I was just wondering if it would be dangerous to anything like the gas tank. Also will I lose any hp from this?
D
Deleted member 87397
May 19, 2007
  • May 19, 2007
Well technically you could probably do it, but you would probably at least want to dump it so all that hot nasty exhaust would not be going straight up to the underside of your car and possibly causing problems. I'd say dump it at least.
RYC CUKR
1,437
Orlando
May 19, 2007
  • May 19, 2007
I have run 2 cars with straight mufflers w/no dumps and no big issues other than you get a pretty strong exhaust smell in the car. Of course you would have that same issue with dumps.
C
CONCRETEWARFARE
208
NEW YORK
May 19, 2007
  • May 19, 2007
did you like the way it sounded with just straight mufflers? Does it sound different at idle? Im just looking for a different sound than the one ive had for years. Also did you notice any power loss?
ponyboy19
1,640
May 19, 2007
  • May 19, 2007
I have heard of road race guys actually boiling the fuel inside of the tank when running without dumps. But these cars are being ran balls to the walls for extended periods of time. I run just mufflers on my 95 with no issues but I don't have a gas tank since the cell sits in the trunk. I will say there is a difference in sound level if nothing else. My UltraFlo's are quite a bit louder without dumps on them.
savegoodautonfg
1,085
  • May 19, 2007
i got my race bullets with no dumps or tailpipes. they sound deep and raspy as hell.
sound great.
vikingpower
656
CWU Ellensburg, WA
May 19, 2007
  • May 19, 2007
Dumps are cheap and easy to install, so you might as well put them on.
Blk91stang
607
North Brunswick, NJ
May 19, 2007
  • May 19, 2007
I have heard of cars boiling the fuel even without being road raced using no dumps.
I say use dumps or have the chance of heating up your fuel and losing performance, possibly causing your car to blow up if it boils. Is it worth the risk for a different sound? Your call.
bobbyd
312
San Antonio/Los Angeles
May 19, 2007
  • May 19, 2007
i dont have tail pipes or anything either but i might be putting some dumps on it.
Foxfan88
My Grandpa has great wood.
Sep 13, 2004
2,487
Miami, Ok
May 19, 2007
#10
  • May 19, 2007
  • #10
all the crap about boiling gas and heating up gear oil in the rearend i think is a LOAD OF CRAP!
i could believe it on hardcore road race cars like stated before, running HIGH rpms for a long time will produce alot of heat, but for a street driven and drag car i dont see a problem.
i ran flowmasters without dumps and currently have bullets without dumps. no problems at all.
you got to think.
once you nail on it, get the rpms up to made alot of exhaust gas going towards the back of the car, it wont take long till your going 50+mph and at that point there will be so much air rushing under the car, even if the gas tank heats up air is coming by and just taking the heat away at the same time.
i wouldnt worry about it.
thumper460
3,022
Orange Park , Fl
May 20, 2007
#11
  • May 20, 2007
  • #11
Dump it or NOT!! There is no HP loss with dumps!! there are these advantages ( if you will) the exhaust from muffler straight out , or a short pipe is that the gas fumes will not exit under the car ( usually in front of the rear Axel, where most mufflers are located) and will seep inside the car.. stink/ CO/ ect.. The "dump or turn down will.. direct the exhaust fume away from under the car chassis, the turn downs will soften the exhaust note.. both are a good thing, unless the solid rumble and fumes is what you want!! Another thing I like to use, on the sat nite street runs ( oops.. we dont do that do we??) I have my dumps aimed at the rear tire tracks!! do a burn out and clean the dirt off the street at the same time, no you have a good tire AND a clean strip of asphalt to launch on.. Just dont idle too long in traffic on a hot day..lol hope this helps...
Just me...................................
Thumper
ryan218
In just 10 years, I'll be old enough to drive!!!!
Dec 28, 2005
columbus ohio
May 20, 2007
#12
  • May 20, 2007
  • #12
sound great.
dads 86 has the same H-pipe and bullets with tail pipes...and the ugly turn downs deep and a little raspy
68stang351
850
9
39
Savoy TX
May 20, 2007
#13
  • May 20, 2007
  • #13
I've had my 68 with no dumps for 7 years, and the 90 with no dumps for 5 now, and had absolutely no problems, other than being able to smell exhaust when idling for long periods of time. The 90 is a daily driver too for my wife, and she has no problems with it.
IMHO, they sound way better that way anyway. Very deep.
M
Bad starter?
  • mason5.0
  • Oct 6, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Oct 6, 2026
General karthief
Surging/stalling! problem or tune?
  • djj62478
  • Oct 4, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Oct 14, 2026
KRUISR
P
Tailpipes for '88 GT
  • pindude80
  • Apr 30, 2025
2K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- May 13, 2025
pindude80
P
G
1982 Mustang GL 5.0 single to dual exhaust conversion
  • Guyton
  • Jun 27, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jul 1, 2025
limp
C
Electrical Fuel Gauge...Help! What did I do or Didn't Do?
  • ChickenDeluxe
  • Sep 3, 2026
Fox 5.0 Mustang Tech Sep 3, 2026
ChickenDeluxe
C
