Electrical No test connector jumper wire?
nope. the grey connector should be- right by the diagnostic plug. You did to good a job of tucking my friend.
He's correct. It would be very easy to cover it up.
If you look very carefully, you can see the gray connector peeking around the upper LH side of the test connector: the wire is very short.
attachment.php
