No turn signals!
  • Thread starter Thread starter 1967coupe
  • Start date Start date Mar 18, 2004
1967coupe
109
Wausau, WI
Mar 18, 2004
  • Mar 18, 2004
All of the sudden my turn signals decided that they didn't want to work any more. The emergency flashers work. I replaced the flasher unit on it. What should I try next?
Tim65GT
1,149
West Texas
Mar 18, 2004
  • Mar 18, 2004
Wrong flasher?
If your emergency flashers work, that eliminates a lot of items. You said you replaced a flasher...there should be a separate one for the E-flashers and one for the signals. Make sure you repaced the one with orange yellow and blue wires.
check this link...
http://www.hammar.dyndns.org/~djhamma/wiring/67exter1.jpg
hope it helps
2nd Mustang
2,488
Southern California
Mar 18, 2004
  • Mar 18, 2004
Direct from section 15-6 , fig. 7 of the Big Blue Book for 67's.
1. Burned out bulbs, or loose socket connections.
2. Open connection at turn signal flasher.
3. Loose or broken wire from ignition switch to flasher.
4. Defective flasher
5. Loose or broken wire from flasher to turn signal switch.
6. Defective turn signal switch.
7. Broken, shorted, or loose wires from switch to lights.
Personally, mine was burnt out bulbs causing only one front and one back on opposite sides not to work...go figure!
A
1966 Mustang coupe / Brake lights and left rear turn signal not working.
  • ArizonaRob1966
  • Nov 3, 2025
Classic Mustang Specific Tech Dec 24, 2025
Mcmahst
Fox Turn signal flasher keeps failing
  • keel
  • Jul 9, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jul 9, 2026
T
Need help 67 hazard flashers not working
  • THS70
  • Jan 21, 2026
1965 - 1973 Classic Mustangs -General/Talk- Jan 29, 2026
D
Turn signals work only with ignition on & Engine off.
  • DienstXIV
  • Jul 2, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jul 7, 2025
DienstXIV
D
68 horn and turn signals stopped working
  • connella08
  • Sep 10, 2025
Classic Mustang Specific Tech Sep 10, 2025
