No Turn Signals
  • Thread starter Thread starter SteedaGT9150
  • Start date Start date Mar 17, 2008
SteedaGT9150
Advanced Member
Nov 10, 2004
1,351
59
68
Maryland
Mar 17, 2008
  • Mar 17, 2008
checked the fuse, its good, replaced ignition switch less than a year ago, any ideas? hazards work fine
bloopbloob
578
Alberta
Mar 17, 2008
  • Mar 17, 2008
did you check the flashers or just the fuse? the turns and hazards run on different flashers. my bet is your turn flasher is toast... they are in different locations on different cars, but on mine (91 GT also), if you lay on your back on the passenger floor, and look/feel up behind the radio/ control knob area, you'll find it there. its a little plastic blue cannister type dealy, and it's press fit into a mounting bracket. took a bit of force, but it eventually just pulls out. hope that helps...
SteedaGT9150
Advanced Member
Nov 10, 2004
1,351
59
68
Maryland
Mar 17, 2008
  • Mar 17, 2008
thanks man ill have to check that out tomorrow
Prime Lord
Crappy Default Title
2,137
199
114
Denver-ish
Mar 17, 2008
  • Mar 17, 2008
+1 on the flasher.
Do yourself a favor and get an "electronic flasher" rather than the stock replacement "thermal flasher" its actually timed and controlled and not just based on the size of your bulbs. You get a little extra "click" in the flash, but they last a HELL of a lot longer.
SteedaGT9150
Advanced Member
Nov 10, 2004
1,351
59
68
Maryland
Mar 17, 2008
  • Mar 17, 2008
wheres a good place to buy them and how can i tell if mine is shot?
mustangfan1990
505
Lenoir, North Carolina
Mar 17, 2008
  • Mar 17, 2008
you can get them at autozone and pretty sure that is it
bloopbloob
578
Alberta
Mar 17, 2008
  • Mar 17, 2008
since you hazards still work, i think they're the same flasher and you can swap them and see if that fixes anything to test it. but they're less than $5 and in stock at most auto stores, and i'm pretty sure thats going to be what your problem is...
fess40
292
Paris, Illinois
Mar 18, 2008
  • Mar 18, 2008
I had the same problem on my '89 about a month ago. Three bucks and a new flasher took care of it.
SteedaGT9150
Advanced Member
Nov 10, 2004
1,351
59
68
Maryland
Mar 18, 2008
  • Mar 18, 2008
ok i guess i am gonna have to go to autozone, hopefully they give me the right part and i dont have to run back 800 times
Nova
128
#10
  • Mar 18, 2008
  • #10
your going to warn part number EL12. before you go and buy one, you can just pop the hazard flasher out, which is in the fuse panel, and put it in place of the turn signal flasher. which should be under the steering colmn on the early car, or behind the glove box on the later cars.
right now, do you even have the clicking of the flasher?
i can explain the circuit to you if you want, and tell you whcih wires should have voltage where. i just had to do this on my car a few weeks ago, turns out the power wire that goes into the multifunction switch was bad.
SteedaGT9150
Advanced Member
Nov 10, 2004
1,351
59
68
Maryland
Mar 18, 2008
#11
  • Mar 18, 2008
  • #11
i put a new fuse in the fuse box for the turn signals and it didnt do anything, when i turn the blinker on it doesnt click or anything, green light doesnt flash, etc
magnj
139
#12
  • Mar 21, 2008
  • #12
Just ran into this problem yesterday. On my 90 lx, the hazards worked but the indicators were going sloooow mooooo. I found the hazard flasher right in the fuse box under the steering column. And the Indicator flasher was basically to the left of the glove box and behind the center console. If you turn your blinker on you should hear it click. Mine was green and kind of plugged into a metal housing with a small nub. It was green, Wagner 224 I think. The replacement is Wagner 522, the same as the hazards...so yea definitely steal the hazards flasher for now and see if that works
Fox Turn signal flasher keeps failing
  • keel
  • Jul 9, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jul 9, 2026
Electrical Turn Signal / Lights Issue
  • 86SilverFox
  • Jun 2, 2025
Fox 5.0 Mustang Tech Jun 3, 2025
General karthief
T
Need help 67 hazard flashers not working
  • THS70
  • Jan 21, 2026
1965 - 1973 Classic Mustangs -General/Talk- Jan 29, 2026
Electrical Hazards dont work - but turn signals do
  • 91EmeraldGT
  • Nov 17, 2024
Fox 5.0 Mustang Tech Nov 18, 2024
Mustang5L5
Z
Turn signals not working at all, but hazards do. 91 fox LX 5.0
  • Zeke1995
  • Jun 22, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jul 12, 2025
Jarhead67
J
