  • 1994 - 1995 Specific Tech
NOISE...DETONATION??
  • Thread starter Thread starter DDSTANG94
  • Start date Start date Jun 30, 2007
1 of 2 Next Last
DDSTANG94
465
FRASER, MICHIGAN
Jun 30, 2007
  • Jun 30, 2007
WHEN i give my car wot there is a noise like a metal slapping something or like a loud tic (kinda) but its more like a "tinging" noise.....i think its detonation timing is a 12* on 87 octane....any suggestions???
Thanks guys!!!!
R
red95gtconvert
382
Ponca city, OK
Jun 30, 2007
  • Jun 30, 2007
Run some Seafoam through it, put higher octane fuel in or back the timing off a little bit.
Stanger007
2,015
Baton Rouge, LA
Jun 30, 2007
  • Jun 30, 2007
That sounds like detonation that you are hearing.
+1 on the comment above.
R
RAD
167
  • Jun 30, 2007
My car is pinging in hot days but 93 octane fuel cured it.
HISSIN50
34
129
Jun 30, 2007
  • Jun 30, 2007
Agreeed. If this is a new noise, it's likely detonation. As everyone said, back your timing down a couple degrees or up the octane.
Good luck.
DDSTANG94
465
FRASER, MICHIGAN
Jun 30, 2007
  • Jun 30, 2007
thanks guys. i think ill try some 93 octane
D
dstang01
170
Vancouver, BC
Jun 30, 2007
  • Jun 30, 2007
Does anyone know how many degrees the stock timing can be bumped so that the car will still run safely on 87 octane? Sorry if I hijacked, im just lookin for a quick answer
HISSIN50
34
129
Jun 30, 2007
  • Jun 30, 2007
There's no magic number - especially on these ping machines. State of tune, ambient temps, how well the MAF is functioning and many other factors play into it.
You will really just have to experiment. Keep bumping till you start to hear pinging and then back it down 1-2* if it's summertime (you might need more if you do this during the winter). There's a point where power goes down but pinging isnt heard by the human ear (the cars always ping - we just dont normally hear it). This is a reason to not run on the ragged edge of detonation.
Good luck.
DDSTANG94
465
FRASER, MICHIGAN
Jul 1, 2007
  • Jul 1, 2007
one more thought on this problem, mine only does it when the motor is warmed up, if its cold and i give it wot it doesn't make any noise. Also whenthe motor is warmed all and I give it wot, the temp gauge goes up higher than it normally runs.....do u guys still think its detonation??
R
red95gtconvert
382
Ponca city, OK
Jul 1, 2007
#10
  • Jul 1, 2007
  • #10
It sure sounds like detonation to me. I think 10* of timing is all you are going to get by with on 87 octane.
Stanger007
2,015
Baton Rouge, LA
Jul 1, 2007
#11
  • Jul 1, 2007
  • #11
Yup, sounds like detonation dawg.
StinkinLincoln
240
Louisiana
Jul 2, 2007
#12
  • Jul 2, 2007
  • #12
more heat causes it to detonate easier.
to raise the timing, can it be done at idle and then hear the pinging and back it off for does it need to be wound up?
HISSIN50
34
129
Jul 2, 2007
#13
  • Jul 2, 2007
  • #13
The engine needs to be under load to test for detonation.
StinkinLincoln
240
Louisiana
Jul 3, 2007
#14
  • Jul 3, 2007
  • #14
so raise the timing a few degrees and get on it, hear some pinging, then back it down 2 and try it again basically?
HISSIN50
34
129
Jul 3, 2007
#15
  • Jul 3, 2007
  • #15
That works.
badstang123
397
Santa Clarita, CA
Jul 3, 2007
#16
  • Jul 3, 2007
  • #16
You are fortunate. Detonation has been the story of my ownership of the vehicle running 91 octane (The best you can get in California) and the stock ten degrees. No matter how many sensors I replace or how much seafoam I run through the thing it still pings.
- Justin
DDSTANG94
465
FRASER, MICHIGAN
Jul 4, 2007
#17
  • Jul 4, 2007
  • #17
is onyone running 14* with 93 octane without problems or is 12 about all im gunna hett out of 93
9
94 Black GT
71
#18
  • Nov 25, 2007
  • #18
i know im bringing up an old thread but i was just curios what seafoam is and what it will do?? thanks guys..
94mustangcobra
126
Valdosta, GA
Nov 25, 2007
#19
  • Nov 25, 2007
  • #19
what type of plugs are you running too, aren't certain types more likely to detonate than others, wich is why you don't run them on nitrous or blower combos. just tossing the idea out there
HISSIN50
34
129
Nov 25, 2007
#20
  • Nov 25, 2007
  • #20
A search (on here or Google) will reveal more than you ever wanted to know.
It's just a top-end cleaner.
94MustangCobra is talking about plug heat ranges. Too cold and they foul, too hot and they begin to favor preignition.
1 of 2 Next Last
D
Loud noise(s) from Engine Bay
  • DuluthFoxbody
  • Oct 25, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Nov 5, 2026
AeroCoupe
Engine Strange Noise
  • burntokita
  • May 8, 2026
Fox 5.0 Mustang Tech May 11, 2026
keel
E
Noise near blower motor behind dash?
  • Ethereal_Zer0
  • Dec 31, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jan 3, 2026
Ethereal_Zer0
E
92 5.0 almost starts
  • Steverino
  • Sep 23, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 25, 2026
General karthief
Electrical MSD Blaster TFI Coil 8227 loud Chirping Noise.
  • PonyGTrider
  • May 25, 2025
2K
Fox 5.0 Mustang Tech May 31, 2025
PonyGTrider
