Noise From AOD
  • Thread starter Thread starter TwinTurbo93
  • Start date Start date Jul 12, 2005
TwinTurbo93
153
Orlando
Jul 12, 2005
  • Jul 12, 2005
I am having a wierd and very loud howling noise coming from my AOD. It happens when starting out from a stop, and goes away if I let off the gas, it also goes away after I get up to speed.
ITs a brand new Lentech Strip terminator w/ brand new PI Stallion 3200 stall non lock converter. It sounds very metallic like a squeal or howl, any ideas?
srothfuss
Last night I stabbed the same guy 7 times in a row
Oct 17, 2004
1,796
Woodward Ave.
Jul 12, 2005
  • Jul 12, 2005
Is your tranny rebuilt? New? Or is it original? The noise that you are probably hearing is the clutch packs grinding down to their last milimeters of metal. If you pull the pan and look at the fluid, I can bet it will be black from all the metal that is being dumped from the clutches.
TwinTurbo93
153
Orlando
Jul 12, 2005
  • Jul 12, 2005
Both the transmission and converter are both brand new with less than 75 miles on it. I did some research and found out that that noise is typical of converter/pump failure.
What would cause pump or converter failure on a brand new tranny with absolutely NO hard drving!?
The Shape
2,224
East ARKANSAS Delta
Jul 12, 2005
  • Jul 12, 2005
I would give the guys at lentech a call and see what they say. I have never dealt wit them , but I hear there customer service is very good.
whtpny
338
Spokane WA.
Jul 12, 2005
  • Jul 12, 2005
I would also make sure that it is not a rearend bearing or something else back there. Those noises can come through the driveshaft and sound like the tranny. Put the car up on jackstands and idle it in gear. Maybe you can isolate the problem. Is your fluid level correct? From what I hear Lentech will work with you. Also if you had a shop put it in get to them soon. I can't remember if that tranny has the TV cable on it. If that is not hooked up it can ruin things in a hurry.
Just some ideas for you. Let us know what comes of it.
TwinTurbo93
153
Orlando
Jul 12, 2005
  • Jul 12, 2005
Thanks guys, the transmission I have is not pressure modulated, ie: no tv cable. I am certain that its coming from the tranny. I will give PI and Lentech a call tomorrow and see whats up. Both Precision Industries and Lentech have been very coperative in the past so we'll see what they say and let ya know! Thanks again.
Engine Strange Noise
  • burntokita
  • May 8, 2026
Fox 5.0 Mustang Tech May 11, 2026
keel
Progress Thread Hello from Nashua, NH
  • sevenup
  • Oct 27, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Oct 28, 2026
sevenup
A
2001 Mustang GT, scorched metal smell and noise from trans/diff?
  • AndyE2255
  • Dec 1, 2025
  • SN95 4.6L Mustang Tech
SN95 4.6L Mustang Tech Dec 28, 2025
gkomo
Fox '87 GT can't get to stay running
  • spilly
  • Mar 29, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jun 20, 2026
spilly
D
Foxbody Misfire 5.0 Swap
  • DPORTER0729
  • May 2, 2025
Fox 5.0 Mustang Tech Jul 13, 2025
90sickfox
