But i'm not seeing the MAF or BAP sensor codes that i would expect with a SD wiring setup, and MA ecu. Perhaps it is the right ECU for the setup.
If you can look at the ECU it will clear it up. The code helps, but the ultimate confirmation will be some digits on the label.
For exampled..
Top left corner it says EECIV SFI- MA12. SFI stands for sequential fuel injection, and the MA stands for Mass Air
As opposed to a speed density HO ECU
SFI is same as above, and SD is Speed Density.
That SD vs MA confirmation is what we need, then we can go from there
For exampled..
gotta fix that, if oil can get out air can get in and on a speed density that's called a vacuum leak not a oil leak lol.
