Non Mustang Brake question please help though
Guero
2,148
Well my dad got a 80 something nissan truck......Its leaking brake fluid what looks to be from the passenger front side brake caliper....Thats a bad caliper correct???Also when you brake the brake, the brakes a very soft till the end were you have to press hard to stop......Thats air in the system right and a a possible bad caliper???
Another question- How do you breed your brake system from all the air inside of it?
Take the wheel off, and have a close look see. I would say possibly brake hose or fitting, or the caliper piston seal, or the caliper piston may have cracked or otherwise failed. Yes when you pump the brake pedal you are pumping out brake fluid from the leak and pulling in air. Don't drive the truck until its fixed. If its the caliper piston seal you could fix it for as little as $5.:nice:
