Non-stang rear caliper question
  • Thread starter Thread starter Swede958
  • Start date Start date Sep 2, 2005
Swede958
712
Austin, TX
Sep 2, 2005
  • Sep 2, 2005
Hey everyone... sorry for the non-stang post but I got a problem with my daily driver I need some advice on.
I picked up this 83 280zx for a daily driver a couple weeks back. Always had no parking brake hold to it. Inspected it and of course failed. Through some new pads in after adjusting the cable didn't work, and it holds now. Unfortunately, the parking lever on the rear caliper will stick when it's actuated fully by the handle. It can jiggle a bit by hand when released, but after you pull the handle the lever stays and has to be beaten back loose with a hammer.
Would it be feasible to rebuild it, as the kit is only like 12$, or not even worth it. I'm new to rear calipers and not sure if the rebuild might fix the lever problem. I'm just asking because the 'new' caliper is like 78$... and I'd rather spend that on gas money. Anyways, would appreciate any advice!
The Swede
bnickel
5,640
lubbock, texas
Sep 2, 2005
  • Sep 2, 2005
usually the rebuild kits are nothing more than seal and o-rings, so it wouldn't help in this case. it sounds like you might have a problem with rust or sediment in the caliper, either in the parking brake mechanism or in the piston bore. my advice check austin imports for a good used one, they usually guarantee them to work so it's worth a shot. i bet you can pick one up for 20-30 bucks from those guys.
Swede958
712
Austin, TX
Sep 2, 2005
  • Sep 2, 2005
are you talking about capitol city imports on congress? as far as I know they have no 280s or 300s.... asked them for a distributer and w/o checking said "no- none of those cars". I have to be honest and say I got the feeling it was cause I was a gringo, I know of one yard that has at least 2 280s, just didn't really think a yard one would be worth it
bnickel
5,640
lubbock, texas
Sep 2, 2005
  • Sep 2, 2005
well buying used brake parts is kind of a touchy situation. worst case is you can buy the rebuild kit and see if you can fix the problem yourself or you can go ahead and but the rebuilt piece. choice is yours
A
Fox Planning on building my foxbody and was wondering if I can get any tips or anything to watch out for!
  • Angelq1028
  • Oct 31, 2024
  • 2 3 4
6K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jun 29, 2025
Robman8028
R
H
Drivetrain 4R70W clutch friction/metals/piston set up questions for transmission guru
  • Hizdudeness
  • Apr 4, 2024
Fox 5.0 Mustang Tech Nov 15, 2024
slow84lx
Progress Thread H/C Swap Problems/Ideas
  • sav22rem22
  • Mar 31, 2024
2K
Fox 5.0 Mustang Tech Sep 10, 2024
AeroCoupe
SN Mustang Magnum T56 swap
  • revhead347
  • May 24, 2024
  • 1994 - 1995 Specific Tech
7K
1994 - 1995 Specific Tech Jun 28, 2026
GearHeadGuy
M
I really wasn't expecting this....... First time Mustang owner.......
  • Mikedd969
  • Nov 27, 2019
3K
1996 - 2004 SN95 Mustang -General/Talk- Nov 28, 2019
Mikedd969
M
