None of my accessory 12Vs work...why?
GToddyT5
553
Hamilton, NJ
I was messing around with some wiring the other day when I was trying to install my XM box. Originally I had my SpeedCal hooked up to the front access outlet near the shifter using a scotch lock. That was working fine and then I needed to install my XM. So I ended up cutting the power and trying to rewire it. Now the front one and the rear one both don't work. I checked the fuses already, so I don't know what the problem is.
loose connection? And did you checked ALL fueses? sometime fuse for ont thing goes, and something totally not related stop working.
e.g.
on my old camry, i pop lighter fuse, and my power seat stopped working
The problem is a broken fuse located in the fuse box under the steering column. It's a 20v fuse, there will be one corner with no fuse and it's located right beside the blank corner, kind of like the first fuse.
