NOOB just bought a 89 fox having problems
''Snakebite''
well i my question is with the bolt on that are on the car "{Trick flow upper and lower intake with 1 in spacer, 70 mm throttle body and mass air tube, cam, bbk ceramic headers, flowmaster king cobra clutch , light weight flywheel and 3.73 gears" do i need to bump up the fuel pressure and get a chip then take to local mustang shop and have them dail it in
I would up the fuel pressure (if not already done?) as well as add timming (if not already done).What is the reasoning your asking these questions?If your having drivability issues a tune would help but like the others said not nessary with the mods with your mods IF the car is running fine.But if anything throw it on a dyno then you atleast know what your A/F is an so on. peace
john:p
