nooby chick from Kentucky
  • Thread starter Thread starter greyfox69
  • Start date Start date Oct 28, 2011
First Prev 2 of 2
blsticms1
23
#21
  • Oct 30, 2011
  • #21
welcome . where in ky are you ? if you need any parts let me know . ive got some odds and ends out in the garage . also wheel you get ready for wheels i want to sell my cobra r and get something else tires have about 3k miles on them .
Boydster
5 Year Member
Apr 10, 2011
301
20
39
Maryville, Tenn
Oct 30, 2011
#22
  • Oct 30, 2011
  • #22
Looks like the plug to the air conditioning WOT cutout relay.
jrichker
StangNet's favorite TOOL
Mar 10, 2000
27,512
2,813
234
Dublin GA
Oct 30, 2011
#23
  • Oct 30, 2011
  • #23
The cone filter for the air intake is a big NO-NO. It sucks up hot turbulent air from the
fan and from around the engine. The stock airbox and flat panel filter is one of the best
cold air intakes made. All that is needed is to take the silencer horn off of the stock unit.
greyfox69
56
kentucky
Oct 30, 2011
#24
  • Oct 30, 2011
  • #24
I started shopping around thinking of doing the MAF conversion. I am thinking in the long run that might be my best option considering its got the E303 already in there. I had a buddy of mine look it over and it seems the PO may have cut some of the vacuum hoses??? why i do not know. So i found a vacuum diagram and Im gonna check it out this week to see if that helps it at all.
jrichker
Mar 10, 2000
27,512
2,813
234
Dublin GA
Oct 31, 2011
#25
  • Oct 31, 2011
  • #25
Fix all your current problems and get the car running good before you do a Mass Air conversion.
If you don't, you'll never be able to tell if there are problems with the conversion or it is more of the
old problems getting worse with time.
greyfox69
56
kentucky
Oct 31, 2011
#26
  • Oct 31, 2011
  • #26
will do. FIrst on the list is to fix the vacuum leaks and replace the intake/airbox that looks like crap. then go from there. PO also removed the AC and when he did he just cut hoses so Im going to try and find an AC to put back in there. Im not dragging this car so weight doesnt matter to me.
Blown88GT
2,283
524
164
Palm Beach Gardens, FL
Oct 31, 2011
#27
  • Oct 31, 2011
  • #27
I just scanned & uploaded the 1988 EVTM to my website. Your timing is uncannily eerie. Maybe something to this Holloween stuff?
I only started working on my car after a long absense. Got a code reader for $25. Your symptoms sound similar to mine; from here, I'm guessing emission control, but the scanner will point you in the right direction.
Flossy
98
Chico, Ca/ Misawa, Japan
Oct 31, 2011
#28
  • Oct 31, 2011
  • #28
Looks like a great start! I love red interior, and it looks to be in awesome shape... Keep us posted on it.
BlackGT89
774
Huntsville, AL
Nov 1, 2011
#29
  • Nov 1, 2011
  • #29
One question would be has it ever run right with the combination you have ?
greyfox69
56
kentucky
Nov 1, 2011
#30
  • Nov 1, 2011
  • #30
I do not know because it was done when I got it. now i cant get the PO to answer my emails. SO im gonna guess no. All i want to know from him is if he did it for sure himself or if someone just told him they did. Im kind of hoping it not done. But no way to know for sure unless motor gets torn into. which if push comes to shove will take it and have a custom map done or when rebuilding it we just put another cam in. Suggestions on which one ? i want to stay SD i think. was considering going MAF but I think Im gonna try to get it running properly as SD
1987stangman
684
24
#31
  • Nov 1, 2011
  • #31
Good question there. When I put my TFS cam in my 87' it bucked and would never idle right. I did the MA conversion right after that and never had an issue since.
There are some SD friendly cams out there, possibly the Comp. Cams #35-308-8 (266HR), Comp. Cams #35-310-8 (270HR). If not not looking to switch to MA but eventually you will want to.
First Prev 2 of 2
F
Fox 1990 Mustang GT 5.0 A9L – Engine suddenly shuts off but immediately restarts when key turned
  • FishermansFriend
  • Aug 9, 2026
General karthief
M
Resolved 1988 Foxbody - Overheating Summer
  • MDrisc
  • Oct 26, 2025
Fox 5.0 Mustang Tech Jul 17, 2026
fasterthangas
F
V6 to V8 Swap info
  • 02_2v_Curtis
  • Jan 11, 2026
1996 - 2004 SN95 Mustang -General/Talk- Oct 7, 2026
2v_johnny
Electrical Innovate PSB-1 is DOA? Am I an idiot? All plausable. Please Help
  • Dontknowchit
  • Apr 26, 2025
Fox 5.0 Mustang Tech Apr 26, 2025
Dontknowchit
'03 GT Fuel Pump/Pressure/Delivery Issue
  • Brodach
  • Oct 21, 2025
  • SN95 4.6L Mustang Tech
SN95 4.6L Mustang Tech Oct 31, 2025
gkomo
