Normal Engine vac???
vristang
4,933
101
124
Seattle
Still having oil issues with the 408w.
What is normal engine vac? What do you guys usually run at?
I am checking mine and I get 17-18 at idle.
Is this too much for the pcv to handle?
I seem to be having vac leak symptoms from the pvc line. When I crimp the line from the pcv to the upper intake the idle drops to a normal range. I also seem to be getting small amounts of oil in the intake too. Is there something I didn't hook up right?
Thanks in advance for any advice
:cheers:
You are right in the ball park. Stockish motors pull 18-22" hg. I am at 19.5".
As you know, your cam can really toss the vac signal out the window, so it sounds like yours is well-mannered. :nice:
Gonna have to think about the crimping part for a little bit......
Good luck.
Thanks Hissin.
I am still struggling with the meaning of values from the vac gauge. This helps.
I think I'll be even happier with the cam when I solve this problem!!!
The best I can figure is that I grabbed the wrong pcv off the shelf, and it is not restricting flow at idle the way it should.
Any other thoughts?
You have a good amount of vacuum at idle... Did you look at the PCV line for any cracks?
As for the oil in the intake, it's probably getting sucked up through the PCV. You can probably get an inline seperator / filter to prevent the oil from getting in there.
Yeah, the hoses are all very new.
I will check at the parts store today, maybe I picked up the wrong pcv. At this vac level most people seem to be ok without using a seperator. I would hate to buy and install extra parts that aren't needed, but that may be my only option.
Thanks for jumping in, I may need some help with the seperator setup later (but I really hope I don't).
I make 9-10" at idle now with my cam after bumping my idle to 1000 rpm. My brakes aren't the best. I have a vacuum canister, but i'm too lazy to put it in since theres no room for it. I cruise at 15".
Well the pcv that the parts dude pulled at the store is different than what I had, the spring was definitely stiffer in the one I had. So, I bought the new one and will run it to work tomorrow (working OT to pay for Mustang Fuel:D), then recheck all the vac readings.
Thanks for all the helpful advice guys.:cheers:
This is great info. Thank you.
Can you provide some cam specs, to help fill in the picture for me?
Can you feel a difference in the brakes between 15" and 10"?
Thanks again.
HISSIN50 said:
I spent about 20 bucks on my separator set-up. I does catch a little bit of oil (this is on the '94).
Out of curiousity how did you set this up?
Does the oil drain back into the crankcase?
Or, is it a catch can that needs to be cleaned out at regular intervals?
I did the common route:
I used a 12 dollar air tool air/oil separator. I removed the line from the PCV valve to the upper, and put the separator in series (with new line - I used hydraulic line, but fuel line should work and fuel line is more mallable).
I used 2 barbed fittings (1/4" thread, 3/8" barbs) on the inlet and outlet of the separator. The fittings are plastic and turn 90* so my lines exit downward from the separator (it is mounted on the firewall). Simple.
I did not run a return line to return oil to the sump - I am not passing that much oil. It is an option though.
There are pics and write-ups on threads, or if you want to see mine, shoot me a PM with email and I can send pics.
Good luck.
