Still having oil issues with the 408w.
What is normal engine vac? What do you guys usually run at?
I am checking mine and I get 17-18 at idle.
Is this too much for the pcv to handle?
I seem to be having vac leak symptoms from the pvc line. When I crimp the line from the pcv to the upper intake the idle drops to a normal range. I also seem to be getting small amounts of oil in the intake too. Is there something I didn't hook up right?
Thanks in advance for any advice
), then recheck all the vac readings.
