if anyone has recently bought a northern (or summit) aluminum radiator, do yourself a favor before you go to the trouble of installing it... check the size on the trans cooler fittings! got mine all painted (wanted the stealth look, not the look- at-me-aluminum look!) filled it with coolant, THEN went to install trans lines, guess what.... cooler bungs werent finished. tech support told me they were supposed to be tapped 1/2-20 threads, buy mine are just barely 1/4" sooooooo, back to summit, drop 65.00 on a b&m super cooler (i got 15% discount, because of the mistake). i wanted a cooler, but not a 28000lb. gvw cooler... at least it has pipe fittings, not hose barbs. o.k, im done venting....
