NOS Activation Question
  • Thread starter Thread starter GearHd6
  • Start date Start date Mar 6, 2006
GearHd6
459
Ashford, CT
Mar 6, 2006
  • Mar 6, 2006
Im sorry if this has been asked before but I did a search and only came up with 5 posts that didnt include what I was looking for.
Im trying to figure out the BEST way to activate my NX kit on a manual transmission car. The WOT switch seems good except for on launch, I dont want it to really activate coming out of the hole. Is there some sort of switching or controllers that work best for this? I dont want a shifter mounted switch either because I want to be able to run as consistent as possible. Any ideas? Thanks!
RYC CUKR
1,437
Orlando
Mar 6, 2006
  • Mar 6, 2006
The best way is a WOT switch in conjunction with an MSD window switch. That way you will only spray when you are at WOT and in the RPM window that you set.
I have mine set for 3000 RPM on and 5800 off. It's also nice cause it prevents overrevving and blowing the motor and also activating to low and having a intake backfire if you have a wet kit.
86bluecobra
Advanced Member
Dec 20, 2004
4,265
12
69
B.C. Canada
Mar 8, 2006
  • Mar 8, 2006
i just have a wot activation. i run 1.6 sixty foot times. in a lunch you foot hits the floor pretty instantly and the nos is activated right away. i have never had any stumbles or anything like that.
rd
3,316
63
109
Ocean Springs MS
Mar 8, 2006
  • Mar 8, 2006
I use a momentary toggle switch on the shifter, plus a separate arming switch.
That way, I can turn it on any time, but it does not come on at lauch unless I hit the switch.
Electrical 1986 Mustang GT Multifunction Switch Question
  • Willybill32
  • Oct 26, 2025
Fox 5.0 Mustang Tech Nov 22, 2025
Willybill32
  • Locked
Drivetrain Adjustable clutch cable questions
  • Scott_S
  • Oct 31, 2025
Fox 5.0 Mustang Tech Oct 31, 2025
  • dan50
  • Jul 18, 2026
dan50
M
2001 v6 heater return pipe leak question
  • mnky99
  • Nov 11, 2025
  • SN95 V6 Mustang Tech
SN95 V6 Mustang Tech Nov 11, 2025
mnky99
M
J
  • JasonB66
  • Jul 23, 2026
  • Suspension
Suspension Jul 23, 2026
JasonB66
J
