NOS Help.
  • Thread starter Thread starter marine_2003
  • Start date Start date Nov 26, 2005
marine_2003
427
Lake County, FL
Nov 26, 2005
  • Nov 26, 2005
Has anyone pieced together a nitrous kit? I have an carburated mustang and want a nitrous kit for it, but want to do it little by little since i have more than one project going right now. If anyone has done it help me out. I want to run at least a 100 shot.
Thanks
Anthony
Rynb15
132
Nov 26, 2005
  • Nov 26, 2005
Really all you would need would be a nitrous solonoid if you want to run a dry kit. A switch to open and close the solonoid(wot switch), a nozzle or plate to hook up to you carb,and then some hosing and a bottle. Im sure im missing something but thats the basics. Not to much involved.
marine_2003
427
Lake County, FL
Nov 26, 2005
  • Nov 26, 2005
I want to run a wet kit. What all would i need for that?
marine_2003
427
Lake County, FL
Nov 27, 2005
  • Nov 27, 2005
anyone?
G
getusummm
156
  • Nov 27, 2005
You will need a nitrous and a fuel solenoid. A purge vavle would be helpful also. You will also need a plate to put under your carb and a fuel regulator for the fuel solenoid. Plus a bottle and a hose and jets to adjust with. I still have a plate and a regulator and I think I have a fuel solenoid if you are interested, pm me.
marine_2003
427
Lake County, FL
Nov 27, 2005
  • Nov 27, 2005
what size line do i need?
bluevenom867
I will have images of molesting stuffed animals in
Dec 15, 2003
1,704
St.Petersburg,FL
Nov 27, 2005
  • Nov 27, 2005
Bottle,bottle brackets,adapter (goes on bottle, it threads the hose on),you can use -04AN but -06AN is better (main feed),into a t-fitting,into a gauge,into the purge solinoid,into the nitrous solinoid,-04AN in the carb plate or use hard line.
Fuel side is -06AN to a gauge fitting,into the fuel solinoid,-04AN line or hard line into the carb plate.
I recogmend having a fuel regulator for the nitrous fuel system,also a fuel pressure safty switch.The nitrous side will have a WOT switch.Even here,you still need a bottle heater,helps out big time.
Need anymore help,let me know.
I might be able to get pics of the parts you'll need tomorrow.
marine_2003
427
Lake County, FL
Nov 28, 2005
  • Nov 28, 2005
Pics would be really helpful. I am going to start piecing this kit together soon.
Thanks
bluevenom867
Dec 15, 2003
1,704
St.Petersburg,FL
Nov 29, 2005
  • Nov 29, 2005
This might help alittle....
marine_2003
427
Lake County, FL
Nov 29, 2005
#10
  • Nov 29, 2005
  • #10
Now what about the wiring and the switch, along with the button for the purge and the button for the nitrous?
bluevenom867
Dec 15, 2003
1,704
St.Petersburg,FL
Nov 29, 2005
#11
  • Nov 29, 2005
  • #11
Im not the greatest with wiring..fairly simple.
Ill go look on holley's web site for instructions.
bluevenom867
Dec 15, 2003
1,704
St.Petersburg,FL
Nov 29, 2005
#12
  • Nov 29, 2005
  • #12
http://www.holley.com/data/Products/Technical/A5051-SNOS.pdf
Here you go,this is insturctions for a carburated NOS Cheater kit.
G
Resolved Smoking Wiring Issue After GT40 Head Swap
  • Grapes
  • Aug 15, 2026
Fox 5.0 Mustang Tech Aug 22, 2026
Grapes
G
Brakes 80 Mustang 4.2 rear chassis brake line for 5 lug conversion!
  • StangPowerLSX510
  • Aug 6, 2026
Fox 5.0 Mustang Tech Aug 9, 2026
limp
1970 Mach 1 voltage regulator
  • 70ivygreen
  • Oct 22, 2026
1965 - 1973 Classic Mustangs -General/Talk- Oct 27, 2026
Mcmahst
H
Forced Induction On3 Turbo Kit- Parts list NEEDED - 302 Stock Motor
  • Hirothecool1
  • Feb 27, 2026
2K
Fox 5.0 Mustang Tech Mar 7, 2026
slow84lx
Engine Edelbrock 1406 install help
  • scottcarp10
  • Dec 11, 2025
Fox 5.0 Mustang Tech Dec 15, 2025
scottcarp10
