ok dont know why but some reason it has been getting hot like up to 250 for no reason. One day after work I started her to let her warm up for 5mins at the most and my buddy says your car is smoken I look over I see white smoke come out the cowl hood every where. I thought the car caught fire then one other time I was driven fine doing 45mph and the temp is at 180 and all of a sudden water come through the cowl onto my window.
I checked the t-stat it works good but I pulled it and I am not running one now and it is doing the same
Iam going to change the water pump out to see if that does it. But I blew a head gasket last fall and it did the same thing now as it did then. Iam trying to get some new heads but they need some work done to them befor I can use them.
because the car would backfire and shoot flames out the header just on that side. I think I might just have warped the head is there a way to check this.
