  • 1994 - 1995 Specific Tech
Not Again :(
  • Thread starter Thread starter click
  • Start date Start date Oct 18, 2005
C
click
142
  • Oct 18, 2005
Rewind to last year:
During the rainy season i noticed that if i stepped on the gas real fast the car would rev in gear then grab and go. What ended up happening was on the freeway my clutch/pressure just blew and my car started shaking. So i replaced it with a King Cobra Clutch Kit. I have gone maybe 6000 miles since then.
So today i went to go pick up my car at American Tire Depot because it was left there over night. And i was driving home in 3rd and wanted to speed up. The car rev'd and then grabbed. WTF? I was soo pissed off, wondering if water got inside the clutch assembly or what... I was in 1st gear and i stepped on the gas and it seems to grab right away with no reving.
What could the problem? I just spent 650 on tires because american tire depot doesnt respect there warranties. I've spent 1300 on tires in a year. Long story.
But what would be the problem going on now. I'm so sick of this mustang. It's been problem after problem... But i still love it to death....
TrueBlue95GT
966
Connecticut
Oct 18, 2005
  • Oct 18, 2005
Maybe your clutch cable is set too tight. The pedal should have a little bit of slack at the top.
HISSIN50
34
129
Oct 18, 2005
  • Oct 18, 2005
What is the point of engagement (high, low etc)?
Good luck.
C
click
142
  • Oct 19, 2005
Yeah there is really no slack on the pedal like when i try to lift it up. And the engagement is maybe like a inch from the top. So VERY VERY VERY high. I have this cable linkage kit...
http://store.summitracing.com/defau...earchinresults=false&N=0&target=egnsearch.asp
HISSIN50
34
129
Oct 19, 2005
  • Oct 19, 2005
That is your issue. You are preloading the diaphram fingers too much (like riding the clutch).
I would dial all of the preload out (till the cable has slack in it). If you are doing this with an adjustable (at the fork) cable, you can use your pinky finger to pull the cable as it enters the clutch fork to feel when you have slack in it. So dial out all the preload and then either leave it with a smidge of freeplay or tighten the cable just a hair (tiny amount of preload). Your pedal should engage closer to the floor after this and the clutch should not slip.
Good luck.
C
click
142
  • Oct 19, 2005
Alright I'm gonna try that today thanks...
Here is the guide to my clutch linkage and it says how to adjust it on page 2.
http://static.summitracing.com/global/images/instructions/fms-m-7553-b302.pdf
HISSIN50
34
129
Oct 20, 2005
  • Oct 20, 2005
For auxillary information, here is an article by Jeremy Thompson (note the article is based on a fox, but the dynamics are very similar):
http://www.50stangs.com/techarticles/clutchcableadjustment.html
Good luck bud.
C
click
142
  • Oct 20, 2005
Thanks Hissin and TrueBlue...I got under there today, and took off the cover to the fork. I felt the cable and it was so tight i couldnt move it at all. I wasn't positive what to do to loosen it, but i removed the small nut on the end, and turn the threaded rod to the left so it loosened. I had it so the cable wasnt completly tight and it wasn't dangling. Then i put the small nut back on and held the threaded rod as i tighten the small nut. I fired it up and went full throttle in 3rd gear and it didn't rev!!! Thanks so much guys!
HISSIN50
34
129
Oct 20, 2005
  • Oct 20, 2005
That is the way to do it. I back them off till I can wiggle the cable laterally and then snug them up a hair. I just converted to a stock cable and FWA and I dont like it - I preferred getting under to adjust the cable since wiggling the exposed cable is the only decent way to feel when you have freeplay.
I tighten it to where there is no slack in the cable and then a little bit more (otherwise the TOB can make noise).
Anyhow, nice work!
00 4.6L V8 new clutch won’t go into gear when on?
  • Timboslice
  • Aug 15, 2026
  • The Welcome Wagon
The Welcome Wagon Aug 21, 2026
N
Vibration after new clutch
  • nipple_looker
  • Sep 20, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 26, 2026
fasterthangas
F
T
Vibrating clutch pedal
  • t.hite10
  • Aug 10, 2026
1996 - 2004 SN95 Mustang -General/Talk- Aug 11, 2026
squeak93
Electrical Code 29 again
  • Creomod
  • Jul 31, 2026
Fox 5.0 Mustang Tech Aug 3, 2026
Creomod
P
Fuel New Eldebrock 1406 problems 1985 GT 5.0
  • Paddyman
  • Oct 22, 2026
Fox 5.0 Mustang Tech Nov 2, 2026
manicmechanic007
